Front-End Loader FEL forks for subcompacts
/ FEL forks for subcompacts #1
bx24d
I have looked at Paynes and other brands of clamp on forks for subcompacts and I'm just not satisfied with the shifting issue that is described. BXpanded.com is a website that sells aftermarked forks that hook around the top lip of the FEL on the BX models (some handy posters have fabricated these on their own and they look effective). I just want to make sure that these are the only two options out there for subcompact FEL forks. Why doesn't someone make a quick attach system that is light enough to make sense? Or, does anyone know of one?
/ FEL forks for subcompacts #2
I haven't found that to be all that great of a problem
/ FEL forks for subcompacts #3
I understand different strokes for different folks. but I bought a set of clamp on forks years ago used them for a week and returned them. I found the location so far out front and the swiveling to be unmanagable except for small very defined loads.
On a subcompact I would be more concerned about lift capacity and stability that far out in front of the loader bucket. I don' think you would find anything that wasn't directly attached to the loader pins (Quick Attach or not) that would give you usable lift capacity and stability.
Andy
/ FEL forks for subcompacts #4
Andy
Well, could they have they changed the design since you bought them and returned them?
Did they have the stabilizer option when you bought yours?
What kind of weights were you dealing with when you tested them?
/ FEL forks for subcompacts #5
I have some cut down truck springs bolted to the bottom of the loader bucket as forks. They are not quick remove but only take maybe ten minutes to bolt on or unbolt. In addition to the forks there are some cut down truck spring prongs mounted on the top of the bucket. These prevent logs from rolling back in my lap. The total cost was about twenty dollars.
The picture posted has been posted before but it is much easier to understand than my description.
In the picture I am using them to spade/dig rocks in a garden:D
/ FEL forks for subcompacts #6
I just bought a pair of the "bucket forks"listed and custom made by my dealer. Check them out here:
PALLET FORK ATTACHMENTS
The functional load bar not only adds extra support to make your bucket practically indesructable but it transfer the weight from on top of the bucket directly to the pins.
The components all come off and can be put on individually so there is no excess weight for the operator to handle.
/ FEL forks for subcompacts #7
I think with the clamp on ones you run a greater risk of bending your bucket. But there are advantages and disadvantages with either style. I prefer the ones that clamp on to the top lip of the bucket.
/ FEL forks for subcompacts #8
This works for me, cost less than $120 and has held 500 lbs. so far.
Rimshot, Apparently the outfit you bought from offers the "load bar" option or a customized pallet fork set up that connects to the FEL arms once you've removed the bucket. On my Kubota BX24, removal of the bucket would take about 5-10 minutes with a rubber mallet and two wrenches. I'm asking for more detailed pics from them of both set ups. Sounds promising. Did you consider the otehr option described above?
/ FEL forks for subcompacts #10
Hi bx24d,
Yes sir, I did consider the bucket removal/fork option. I think I made up my mind to utilize the bucket mount pallet fork for two reasons. The first of which is convenience in that I don't need to R & R the bucket even though it is easy to do. The second reason is I like what the load bar does for the bucket. With that load bar attached, this bucket has to be literally twice as stout as the way it came from the manufacturer and it is a good bucket to begin with.
Incidentally, that is no tube or pipe that goes through those eyes to secure the forks. It is a solid core of round stock steel of 2" diameter. This set of forks is obviously very well conceived and the workmanship is excellent with heavy stock and fine welding. My hat is off to Michigan Iron & Equipment of Morrice, Mi for fabricating this heavy duty fork for a very reasonable price.
rimshot
Rimshot, I see your point. The bucket setup looks great. Do you have any difficulty with visualizing the tips of the forks for placement while you're sitting in the operator's seat?
/ FEL forks for subcompacts #13
Rimshot, I see your point. The bucket setup looks great. Do you have any difficulty with visualizing the tips of the forks for placement while you're sitting in the operator's seat?[/QUOTE
Hi bx24D,
I suppose if visibility of fork bars is an issue the pin model is the way to go. If I skewer the refrigerator with my new forks I think I shall blame the spotter I shall be certain to employ and watch up close as I move to get into lifting position. There's no way I would trust my steadiness without somebody watching. But I don't think fork tip visibility is going to be a show stopper anyway. The first thing I do if heavy lifting is in order will be to raise an old pallet slightly just short of the pickup truck tail gate premounted on tractor forks. Something like a refrig or washer/ dryer can then be manhandled from the tail gate down to the pallet. That will diminish chances of screwing up........even for a clutz like me.
rimshot
/ FEL forks for subcompacts #14
I finally bought a set of LandPride PF10 clamp on forks for moving mulch bales 5 at a time on a pallet which I attached to the forks, so when the bales arrived at the compost pile I could just dump them and go back and load 5 more onto the pallet...moved over two hundred that way...had to tighten the forks twice...for a simple one-off task they worked well...;)
Land Pride Pallet Forks
/ FEL forks for subcompacts #15
these are the greatest things ever. these and the tooth bar
/ FEL forks for subcompacts #16
Is that just channel iron for the forks and frame? Nice setup. I only need lightweight lifting and this looks like something I could build myself.
Do you have additional photos?
Thanks,
Clem
LandHonor Hitch Adapter (A62183)
LandHonor Hitch...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
2000 RAVENS 39' FRAMELESS ALUMINUM DUMP TRAILER (A63290)
2000 RAVENS 39'...
NEW HOLLAND 352 GRINDER/MIXER (A63745)
NEW HOLLAND 352...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2026 Kearney 8' x 20' (A62180)
2026 Kearney 8' x...
