Looking for a toolbox; 1500 series
/ Looking for a toolbox; 1500 series #1
DMF
Mass
Massey Ferguson 1552 Cab Model
I just got my 1552 cab model and I'm looking for ideas for toolboxes and where to mount them. Any ideas folks?
/ Looking for a toolbox; 1500 series #2
You do know about the "toolbox" directly behind the seat I hope? Probably not the most convenient, but handy storage if nothing else.
/ Looking for a toolbox; 1500 series #3
I have the 1547 Hydro model.
Look under the floorboards on your left side when sitting. Under the floorboards there is a ton of room to put a toolbox and it is out of site.
/ Looking for a toolbox; 1500 series #4
If the one beihnd the seat is too small you might consider mounting one on the outside below the upper rear cab window
I kind of laughed when the dealer showed me that one...I could maybe keep a pair of gloves in there, but not much else! :)
I'll have to look into this area.... I have a cab model and I know my manual stated that the reservoir for the windshield washer fluid was located there...I don't know if there is additional room besides that...?
I have been thinking about that myself.... I found these two:
TRACTOR TOOL BOX RED - Agri Supply
Valu-Bilt
I think I would go with the first one as it's a little bigger...
Thoughts?
Well, I ended up getting the box from Agri-Supply. It came with "universal" mounting brackets, alas, no directions on how to assemble them...
No problem, I is an engineer! :)
I was able to mount the box using existing holes and brackets on the tractor and I used their "universal" brackets as well. My only changes to their design (so far) was to utilize lockwashers on their hardware. It appears pretty sturdy so far; it managed to stay on the tractor after a couple hours of brush-hog work.
I'll try to get some photos this week/weekend and post them up!
OK as promised, here are the photos. You will note that the box has a somewhat unusual mounting method; the brackets to the left and right do not connect in the middle; the box wedges into the brackets via a groove running along the back of the box; the box is then secured using the thumb screws. Once secured, the whole system is quite rigid. At first, I was going to replace the thumbscrews with regular hex bolts but then I thought it might benice to remove the whole box of tools and bring them to the front of the tractor, for example to perform a repair...
Anyway, here it is, let me know what you think!
2022 EZ-GO ELITE...
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
Auger Cart (A65640)
Auger Cart (A65640)
Bandit Wood Chipper (A62613)
Bandit Wood...
