Mowing LK3054 finish mower
/ LK3054 finish mower #1
OFarrell
NH Workmaster 60
Does anyone run wide area finish mowers with these tractors? I would like to pull an 10-12 foot mower. I have been looking at the landpride AFM4211 and Bush hog TD-1100. Any thoughts?
/ LK3054 finish mower #2
Your asking a lot out of that tractor.
You would be running every last little ounce of power that tractor has.
Hope your running fairly level ground
/ LK3054 finish mower #3
I ran a 6' wide First Choice finish mower with mine and it is all it wanted. It did fine but I wouldn't even try anything bigger then that.
/ LK3054 finish mower #4
I can't even begin to see it working out very well . . . and if it does it may just be the slowest mowing job in the history agriculture. I run 7ft. finish mower with my DK45 and all though I can mow in mid range flat out I can tax the tractor if get into some heavy wet stuff and don't lift.
What hp/size tractor should I consider? This is going to be used to cut 10 acres bi-weekly.
/ LK3054 finish mower #6
I think it depends on the mower you are looking at. Do you need a gang of finish mowers for 10 acres? I can't see why you would unless you are cutting something like a park or golf course. Those gang mowers are limited unless you have another small lawn tractor/zero turn type mower for smaller more intimate mowing. Furthermore, they are expensive just for 10 acres. I would save my money and by a large 3pt finish mower and go that route. I have 4.5-5 acres of pasture to cut plus I do my neighbors stuff with either the finish mower or the rotary. One is 7ft. and the other is 6ft. and there is no way a gang mower would work with the exception of my large pasture. I would have it done it about 20 minutes but then what. I spent a large chunk of change on it.
Either way I'd be looking at a 35-40 horse tractor. Are you doing anything else besides mowing?
I've got a 52" Exmark but that's way to slow for 10 acres. I won't be doing anything else on this 10 acre lot but mowing. I'm trying to minimize the amount of time spent on this lot. I did look at 3 point single deck finish mowers but going from a 52" deck to a 72" deck didn't seem like that much of a difference. I would imagine that the tractor puts more hp to the ground than the 52" Exmark.
Mark.r how long does it take you to do 5 acres with the 6 or 7 ft mower?
/ LK3054 finish mower #8
A good rule of thumb for Finish Mowing is 3-4 pto hp per foot of mower width. That number can change up or down depending on conditions, but it is a good place to start.
/ LK3054 finish mower #9
It take me about 3 hours to do it all with the 84" finish mower.
Do you know what the cost of the Landpride gang finish mowers are? At one time I had heard 7k and another time I had heard 12K. I friend of mine had one that he inherited from the owner of the own he purchased along with a NH TC45 or TC55 tractor he never used it but I know his wife sold it CHEAP on craigslist. So cheap I don't think they spoke for a week or so. At the time I didn't have a tractor that could pull or I would have bought it just out of principle.
/ LK3054 finish mower #10
Figure about $1000/ft of width for a BEFCO Flex-Wing Mower.
/ LK3054 finish mower #12
Takes me 3 1/2 hours to finish mow around 7+ acres with an 84" rear finish mower.
/ LK3054 finish mower #14
I mow about 20 acres with a 60" brush (rotary) mower. Takes me about 12 hours (machine time). I normally run between 1.7 and 2.7 mph (never faster) depending on where I am - slower in plenty of spots.
Terrain is somewhat hilly and there are some rocks & groundhog holes to avoid. I also mow carefully in my overgrown (trees still need to be thinned out and pruned/shaped) apple orchard.
Well, I think i'm going to go with an 84" mower since that's about the max my tractor can handle. It's a shame since I had the opportunity to but a 3 yr old batwing for cheap.
As far as a rear discharge single deck finish mower, are there any brands to stay away from?
/ LK3054 finish mower #17
I would say if you were going to mow once a week I would say go with the big batwing one. The 11ft bush hog say minumum 30hp. I have seen a JD 4300 with the same mower at the local school which has around the same hp as your tractor and it seems to run fine. They move along at a good pace and it doesnt seem to bog down any.
This is just my opinion but I would go with the bigger one and if the grass gets to tall take half width passes. I think choosing a finish mower is the same as choosing a bush hog. One big blade takes more hp that 2 smaller ones. Same with finish mowers, you have 3 small mowing decks instead of 1 big one. This saying a 7ft model takes the same hp+ than the 11ft. Also if you have uneven ground I would think the larger model with 3 smaller mowing decks would float better that the large 7ft deck.
hope this helps.
/ LK3054 finish mower #18
hope this helps.
I disagree 100% , but to each his own. Good luck, what ever you do.
2019 BOBCAT T870 SKID STEER (A62129)
2019 BOBCAT T870...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
Sunflower Yard Art (A61569)
Sunflower Yard Art...
1997 International 4900 Chip/Dump Truck, VIN # 1HTSDAAP4VH459252 (A61165)
1997 International...
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
2023 John Deere 8R 280 Tractor (A63109)
2023 John Deere 8R...
