Mowing LK3054 finish mower
   / LK3054 finish mower #12
Takes me 3 1/2 hours to finish mow around 7+ acres with an 84" rear finish mower.
   / LK3054 finish mower #14
I mow about 20 acres with a 60" brush (rotary) mower. Takes me about 12 hours (machine time). I normally run between 1.7 and 2.7 mph (never faster) depending on where I am - slower in plenty of spots.
Terrain is somewhat hilly and there are some rocks & groundhog holes to avoid. I also mow carefully in my overgrown (trees still need to be thinned out and pruned/shaped) apple orchard.
Well, I think i'm going to go with an 84" mower since that's about the max my tractor can handle. It's a shame since I had the opportunity to but a 3 yr old batwing for cheap.
As far as a rear discharge single deck finish mower, are there any brands to stay away from?
   / LK3054 finish mower #17
I would say if you were going to mow once a week I would say go with the big batwing one. The 11ft bush hog say minumum 30hp. I have seen a JD 4300 with the same mower at the local school which has around the same hp as your tractor and it seems to run fine. They move along at a good pace and it doesnt seem to bog down any.
This is just my opinion but I would go with the bigger one and if the grass gets to tall take half width passes. I think choosing a finish mower is the same as choosing a bush hog. One big blade takes more hp that 2 smaller ones. Same with finish mowers, you have 3 small mowing decks instead of 1 big one. This saying a 7ft model takes the same hp+ than the 11ft. Also if you have uneven ground I would think the larger model with 3 smaller mowing decks would float better that the large 7ft deck.
hope this helps.
   / LK3054 finish mower #18
hope this helps.
I disagree 100% , but to each his own. Good luck, what ever you do.
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
110 GALLON FUEL TANK (A52708)
110 GALLON FUEL...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2015 KENWORTH T660 SLEEPER TRUCK (A58214)
2015 KENWORTH T660...
JOHN DEERE 6115D TRACTOR (A58375)
JOHN DEERE 6115D...
