WHY DO I NEED A REMOTE PORT?bx-23
/ WHY DO I NEED A REMOTE PORT?bx-23 #11
Here is the cheapest one from NT:
Valve
And here is a good on from the SC:
Valve
Valve
Valve
KENNYD ,YOUR A GREAT BUDDY ID LIKE TO BUY YOU A BEER!!1
This is so funny i printed out that one from NORTHERN last night i have it in my hand.i didnt see the words OPen centered so i wasnt sure.
the one from the other place is the same valve correct[and alot cheaper]OK MAKE IT TWO BEERS:D:D
/ WHY DO I NEED A REMOTE PORT?bx-23 #13
No problem...I have always though that NT was expensive on most things, plus they have very high shipping rates. SC has great prices, great service, and fair shipping. They also have a very help tech line you can call. While you are ordering from them you can get some fittings that you will need as well...
/ WHY DO I NEED A REMOTE PORT?bx-23 #14
Alan,
The valve that I installed on my bx23 was a SC #9-4501 2 spool Eaton Cessna 30922 OC valve. I think it would be a mistake for you to install a one spool valve. Think about Top and Tilt down the road. I love my setup.
Alan,
WHATis that,RON?Is that something for my rear blade,or rake?Iwas thinking i was going to plumb my backhoe thumb,when i get the funds.Iwas going to add another valve bank on with the others in my hoe,like i saw another do here a while back.
/ WHY DO I NEED A REMOTE PORT?bx-23 #16
The valve that I refered to is from Surplus Center. Look it up in their catalog. That valve had been recomended several times on the forum. I think Junkman had used it, but not for sure. Anyway,. I really like my installation. I don't have tilt on my box blade, but what I have done is install a dozen wheels on the back of the blade to lift the BB and roll out the dirt as it is spread. This is how I was able to build up a pad for my new work shop. Spread and compact at the same time. I would lay down about an inch or two of clay, dampen, and then run my sububan back and forth to really pack it in tight. Portions of the pad are better than two feet thick. It was harder to dig for the footings through the builtup pad than it was in the native soil. What ever valve you use, I would go for at least a two spool valve.
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2019 Ford F-550...
2013 PRATT INDUSTRIES GARDNER DENVER TRIPLEX FRAC PUMP (A60736)
2013 PRATT...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
2011 Chevrolet Cruze Sedan (A59231)
2011 Chevrolet...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
John Deere 5100M (A53317)
John Deere 5100M...
