adding backhoe thumb, how to power it
/ adding backhoe thumb, how to power it #1
alaskakubota
I want to add a thumb to my 3130 with BH90 backhoe that I just had installed yesterday, and it kicks some good AZZ. Anyways, just had to say it works good, I want to add a hydraulic thumb to it. I have 2 power beyond outlets on my tractor because the backhoe runs on one, and the grapple works on the second. So I will be adding a third power beyond to run the thumb. How can I run the thumb sitting on the backhoe seat and not having to turn around and grab the lever? Is there a foot control that a guy could install that would run the thumb? Do other people use a joystick somewhere? Any help would be great.
/ adding backhoe thumb, how to power it #2
You could use a 12v electric hydraulic 4 way valve, with a thumb switch on your joystick valve. They run about $100.00. About the only problem is you have full pressure at the git go, where as a lever valve could feather the action.
/ adding backhoe thumb, how to power it #3
You could use a 12V diverter valve plumbed to your curl outputs on the hoe.
Put a foot switch on the floor to activate valve.
/ adding backhoe thumb, how to power it #4
Just to clarify: You do NOT have 2 "power beyond outlets" Power beyond is defined as a "loop" of constant hydraulic flow that is used to power attachments that have their own valves, like backhoes and log splitters. Power beyond does NOT have handles to control them.
What you have is two hydraulic "remotes" and want to add a third remote. Remotes have their own valves to control cylinders on attachments.
Please understand that I am not criticizing what you wrote, I only want you under understand the differences and proper terminologies.
I assume to operate you backhoe you need to hold one handle open on one of your remotes?
I electric diverter is a great choice, it basically "splits" one circuit into two electrically. Do a search for "diverter" for a lot of good reading on the subject.
/ adding backhoe thumb, how to power it #5
I agree with everything BUT the $100 part-I have not seen any that cheap.
I have a few questions about this. Looking further into this, would I get the hydraulic flow from the hydraulic remote or where do I tie into this? Does anyone have any pictures of this switch that hooks up to my lever? Sorry for so many questions, just dont know enough about this and want to do it right. Who has put a thumb on and made it work?
/ adding backhoe thumb, how to power it #10
If you go the diverter route, then you would install it AFTER the control valve that operates the curl circuit (or any other circuit-even one of the outriggers will work) So basically you would have hose run from the stock control valve, to the input of the diverter valve, then hoses from the diverter to the original cylinder AND to the grapple cylinder. If you search "diverter" like I said before you should see plenty of pictures of handles-but they will mostly be on the FEL joystick, as that is what most of the diverter threads are about, adding a circuit to a FEL to operate 4n1 buckets, grapples and snowplows.
If you go the electric valve route like JJ posted, then that would get installed on the main lines that feed you backhoe now, and you would need a 3 position rocker switch (ON-OFF-ON) to operate it versus a single mopmentarty switch to operate a diverter valve.
/ adding backhoe thumb, how to power it #11
I just finished (today) putting a 12v diverter valve on a Ford backhoe from the bucket control circuit to power a power angle snowplow. With the 12v switch in the off posistion the bucket works normally, with the switch on the plow will angle left/right. Now, if I, instead, tied into the pressure line from the pump to a directional control valve to the plow would that have worked?
/ adding backhoe thumb, how to power it #12
I made my own thumb and made it work.
I know you're wanting to use hydraulics so this may not be of interest to you, but this is an alternative ... no hydraulics, all mechanical articulating. Here is a thread on how I made it and some pictures of it. I think there's also a video of it in the thread.
It works great!
Homemade Articulated Mechanical Thumb
/ adding backhoe thumb, how to power it #13
Sounds good on the surface, but Surplus Supply may be cheap but cheap doesn't help when the company is useless. No support there. I highly recommend paying the long dollar and staying away from Surplus Supply. By the time you get done with them it will cost you more.
/ adding backhoe thumb, how to power it #14
You brought up a two year old thread to bash a supporter of the site:confused2:
You are the FIRST one I have heard complain about them.
/ adding backhoe thumb, how to power it #15
I have used Surplus Center for many many years and have never had one single issue with them. In fact once I screwed up and ordered the wrong valve, they took it back with no problems and sent the new valve out the same day. Everytime I have called their technical support has been excellent. So I'm with Kenny not understanding the bashing of Surplus Center.
/ adding backhoe thumb, how to power it #16
I just started using Surplus Center (twice so far) have had no issues.
/ adding backhoe thumb, how to power it #17
I have used SurpCntr many times since about 1995. I would hardly call
them cheap, but I would say they are an excellent supplier and I have
plugged them on TBN before. (Note to SC: please send me a discount
coupon!)
If I had to go more often to industrial distis for hydraulic stuff, I would
likely be doing less hyd projects.
Once SC sent me the wrong part (an electric motor), so I contacted
them and they sent the correct one right away.....they did not even want
the wrong one back.
I admit that I do not call in for tech support, mostly cuz they provide
lots of tech details of their products on the website.
/ adding backhoe thumb, how to power it #18
I have used the Surplus Center several times over the last few months and find them to be nothing but top quality.
/ adding backhoe thumb, how to power it #19
Ditto to the other comments: No problems with SC! ~Scotty
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
Caterpillar 446B Backhoe (A66285)
Caterpillar 446B...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
John Deere 1720 (A64126)
John Deere 1720...
