JD vs Cub Yanmar 3200
/ JD vs Cub Yanmar 3200 #1
cowdoc
Member
Central North Dakota
Cub Yanmar EX3200
I would like to say that my family has owner many JD's over the years and I have great respect for their good, solid products. I just purchased a Cub Yanmar EX3200. What JD model is this comparable to/copied after? I am specifically looking for rear remote hydraulic parts as cc/yanmar does not have this as an option yet, and I need hydraulics. They do have a power beyond kit available. Thanks for your input.
/ JD vs Cub Yanmar 3200 #2
Hiya,
I don't think your going to be able to get a bolt up kit for rear outlets from Deere even though both are Yanmar based.
At the 4H fair last weekend there was a Cub dealer with all the cub/yanmars on display. I looked at all of them and it didn't look like they had a lot in common with current Deere models.
You may be looking at going to your local hyd supplier and sourcing the parts there.
My 2 cents,
Tom
/ JD vs Cub Yanmar 3200 #3
If you need it quick as in before they (if) offer it, I'd get the PB and rig up my own remotes....Theres enough posts on here that it should be fairly straightfoward...
/ JD vs Cub Yanmar 3200 #4
It looks a lot like my 790 (now called 3005) (instruments, SCV, fenders, almost everything on the rear). Of course it has hydro so obviously they made some changes. Even for the 790 all JD offers is PB and a kit that lets you move the SCV control from the front to the rear by moving the Quick Discounnects from the FEL. I mounted a 3 port valve on the right fender and ran my PB to it and use it to control my TNT and my angle for my FEL blade.
/ JD vs Cub Yanmar 3200 #5
Cub made several improvments to the 790 which is the base model for that tractor. I'd suspect they are too different for the kits to carry over.
2014 KBH 40' Hopper Bottom Trailer (A64047)
2014 KBH 40'...
John Deere 7230 (A62180)
John Deere 7230...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
16ft Cattle Panels (A64047)
16ft Cattle Panels...
2000 Ledwell 48ft. Step Deck Trailer (A64047)
2000 Ledwell 48ft...
Jacobsen LF510 5 Gang 100in. Commercial Reel Mower (A61572)
Jacobsen LF510 5...
