john deere 1070 won,t start
/ john deere 1070 won,t start #1
MICHAELL
i think i may have run it out of gas but the fuel filter tanks were both full i was not getting fuel to the injector heads i opened up the lines on top of the pump
and adjusted them i have fuel at the injector head i blead out the lines and it still won't start any ideas
/ john deere 1070 won,t start #2
Have you opened each injector line at injector? ..just to be sure, also more information would help..does it crank okay, not slow? Any debris or water in filter? Does it pop, sputter, or does it crank fine and not even a burp?
Check all fuses, relays etc. and get back to us.
BTW, Welcome aboard..
from the beginning of this trip i though that there was something electrical are the some relays that have to do with the starting. it seems to turn over just fine but not even a hint it is going to start yes i cracked all the injectors . i got rid of all the bubbles and not a burp.
/ john deere 1070 won,t start #4
I recently sold my 770 and with that went my repair manual, it covered the 1070 as well.
Unless we start from the begining and check the major components it's just hit or miss, and without my repair manual I'm hesitant to suggest the next step. If you've checked the fuses and relays, and made sure everything is getting power, perhaps the thing to do is buy a repair manual, although maybe someone here may be able to guide you through the steps.
Diagnosis is an underappreciated part of mechanical repair, it takes an understanding of how the machine works and where to check for power, ground, signal, pressure, timing etc, and why..
1: engine cranks..battery is most likely good enough to start engine
2: fuel is getting to injectors, is fuel getting into cylinders?
3: are injectors getting signal, or enough pressure to open? most likely not, but you need to check.
If I remember right the 1070 has a direct injection engine, with no computer (I could be wrong). That would mean injectors are pressure operated by the injector pump timing. (if this is wrong, please correct me)
Luckily I never had to do more than minor service to my 770, I did replace the alternator bearings, but that's it.
I've worked on gas auto engines for the last 30 years, but I'm not a diesel tech, however there is some talent here, hopefully one will join in with the next logical step.....
MICHAELL, hope something simple has happened, but not familar with the 1070 enough to guess what.
HowStuffWorks "Diesel Fuel Injection"
/ john deere 1070 won,t start #5
I have a 1070 so here goes:
Does the fuel shutoff solenoid click loudly when you turn the key? Is the seat switch stuck (you need weight on the seat and it must compress unless you pull the switch up to run it without an operator). Gears in neutral? PTO sensor closed. If it cranks, is it good rpm? Any smoke: white or black?
If you really think it ought to run, tow it behind a truck until it lights up. You need some real rpm so choose the right range and gear selector.
I'll look in my manual when I find it and see what else they recommed....
thanks for the reply's guy's my guess is that the fuel is not getting past the in jectors if any one understands how direct deisel injector works that would be helpful i also liked the idea of pulling the tractor in gear to get it rolling i would like to know how fast and how far what gear what gear range i have three
/ john deere 1070 won,t start #7
The speed to pull it depends on what you have to pull it with. A simple downhill run could do it. A few guys here have taken my suggestion and it worked for them. I'd go with 2nd range, 1st gear for 'starters'. Something to pull 2000 rpm. This could take a few yards to 'pull it off', but if you know its a fuel supply issue, this will work. Be sure to check both filters and make sure the fuel shutoff valve at the tank filter is open. This ought to remind you of a cold weather start. She'll huff and puff for a few yards but then it will take off. Make sure you give yourself enough rope because when it starts running, you could run into your tow vehicle.
BTW: put it in 4wd to prevent rear wheel slip.
i tried letting it roll down hill i pulled it with a pickup truck it cranks but it won't
turn over i am getting ready to take the plate that holds the key switch and look behind there is there anything like a ground safety or some other type of safety with the good Ideas i have gotten so far I am supprised it has not started
/ john deere 1070 won,t start #9
My guess is you have a problem with the fuel shut off solenoid. It is located on the right side of the engine and has a link connecting it to the injection pump. As a test, you can pull back on the link by hand while you crank the engine and it should start. If that works, then you either have a bad solenoid, control module, or a loose or broken wire somewhere in that circuit. I have attached a picture of the solenoid. Just pull back on item #9 while you crank it. I am betting it will start.
thanks for the suggestion but unfortunately it still wont start the solanoid pulls in fine every idea seem to point in the right direction but i still connot get the thing to crank over is it possible that the injectors got clogged and is there any way to know if the fuel is getting past the in jectors
/ john deere 1070 won,t start #11
When cranking; are you getting white smoke?
/ john deere 1070 won,t start #12
I'm no diesel mechanic; so, consider the source...
Direct injection diesel engines force fuel into the combustion chamber and "crack" open the injector with high pressure; yes?
Bad or failing injector pumps cause an engine to be hard starting and rougher running (uneven) with poorer fuel economy; yes? I believe that this is a slower developing condition and not something that typically happens "overnight"; yes?
That said, has your 1070 been acting up for awhile? It could be your fuel injector pump..
It's not the fuel shut-off selenoid... you've got fuel to the pump, etc. and you don't have fuel down the injector lines to the injectors, yes?
AKfish
i do have fuel to the injectors it just wont start
/ john deere 1070 won,t start #14
Pump not developing enough pressure to open the injectors..?
Not to get too far off track here but --- have noted a post or two related to pump failures possibly related to the new ULSD fuel.
I have been using PowerService for the past 3 years (gelling problem, initially) and have since seen (on TV) diesel owners that have had pump failures with the new diesel fuel.
Might need to have the pump checked out at either your dealer or a good diesel shop.
AKfish
/ john deere 1070 won,t start #15
Is it cranking too slow? If it's not cranking fast enough it's not going to have enough heat in the cylinders to fire even though you have fuel. If it is cranking slow try connecting another vehicle and jump start it and heat the glow plugs for 15 seconds. Also the 1070 should have a hand operated primer pump right under the injector pump. There shouldn't be any need to crack lines if you run out of fuel. You can tell when you pump the pump if you are getting fuel as you will start to feel resistance as you pump. I don't think you can pull start this tractor as it would need to be in neutral to start. Unless you bypass the neutral kill switch.
Sincerely, Dirt
/ john deere 1070 won,t start #16
does it have a fuel cutoff solenoid? or do you manually pull a lever to shut it down? if you shut it off with the key then I would check the fuel cutoff solenoid on the injection pump. Turn the key to on the push in the plunger and try to start the machine, you can also pull the boot back and wipe the piston clean. a little wd40 and put the boot back on.
/ john deere 1070 won,t start #17
thanks for the suggestion but unfortunately it still wont start the solanoid pulls in fine every idea seem to point in the right direction but i still connot get the thing to crank over is it possible that the injectors got clogged and is there any way to know if the fuel is getting past the injectors
Make sure that your fuel supply screen at the tank isn't clogged. Then open the bleeders on the fuel filter(s) and make sure that you have fuel there with no bubbles. I fy ou don't, bleed that till you do. Is there a bleed screw on your injection pump? I f there is, bleed that. Then redo the injector bleed.
/ john deere 1070 won,t start #18
The only way to know for sure, is to remove the injectors and connect them to the fuel lines while injector is hanging in the air. Then crank engine and see if any fuel sprays out.
/ john deere 1070 won,t start #19
Both these suggestions will give you some real answers...Get some local help....or test it yourself.
1st: Do you have enough fuel pressure.
2nd: if not .. why not . If yes, what are you lacking..., injector operation, compression, timing.
AKfish
OR....borrow or rent a fuel pressure tester for a diesel engine ..and a high pressure engine compression tester..From what you said earlier : you aren't sure if you ran out of fuel..right? Maybe your pump got just worn enough to lack the pressure necessary to trigger the injectors. (we hope not)
It's time to get on the scene help with this ..or get readings..ie: fuel pressure...cylinder compression...fuel pump timing...
/ john deere 1070 won,t start #20
what u need to do is take a gasoline soaked rag and hold it over the intake, HOLD ON TO IT TIGHTLY. then try to crank the engine if it does nt crank its the injectors. If it does crank but runs either eratically, or smokes excessively. its the injector pump
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
2016 FREIGHTLINER CASCADIA (A67714)
2016 FREIGHTLINER...
2018 BRADLEY MACHINE MINI VAC TRAILER (A67714)
2018 BRADLEY...
