6000 PTO lever
/ 6000 PTO lever #1
Bethpage Circus
Do you get to the PTO lever connection from the front end of the Mahindra 6000 series tractor or from the rear end? My nephew needs to replace the lever.
Also, is there a repair manual on-line? The dealer said "Just get on line" but they forgot to ask "where"!?!
/ 6000 PTO lever #2
Why do you need to replace the PTO lever? It just sounds like an illogical part to need to replace, and I would hate to see you splitting the tractor if it isn't needed.
/ 6000 PTO lever
Mr. LaWall,
The ringmaster just told me the following...A.J., wife of TJ, was using the tractor to run the bush hog. When she brought it back, the lever to the PTO was and is loose, with no reaction to moving the lever. The lever wriggles around and apparently is not connected to the PTO. Possibly a cotter pin or similar connection has broken or something has slipped off. Anyway, the PTO does not engage and the lever is much too sloppy and loose. This leads the tractor owner to think that they need to get to the place where the PTO hooks to the PTO lever and hook it up once more.
Does that make sense?
Actually, what is needed is to re-connect the lever to the PTO.
They are used to working on John Deeres, Olivers and Massey-Fergusons. This is the first time the Mahindra has done something like this.
Thanks, Lucy B at Bethpage Circus
/ 6000 PTO lever #4
Sounds like the roll pin may have sheared. I have not had to replace one on the 00 series before but I do know the others (25 series) we've worked on in the past have been a pain to get to. I'll ask our mechanic when he gets back in from lunch.
edit: Mechanic says you'll have to get the other half of the piece the lever connects to out through the triangle hole where the lever mounts up to and either put a new roll pin in or weld it then reinsert it back in. Most of the time you have to remove the floorboard and possibly even the fender to get it back in due to the length of the PTO lever itself and the angle you have to put it in.
convert
/ 6000 PTO lever #5
let me know if you are able to view that image or not.
/ 6000 PTO lever
RedRiver Sir! You have just made a couple of old tractor jockeys very happy!
They both left with a grin on their faces, even if my printer decided against
working again! Thank You so much. We do so appreciate the help! I'll let you know how it works. The diagrams came through fine and they both knew what was being shown!
The ringmaster said to tell you he wished you were down the road instead of
two states south!
/ 6000 PTO lever #7
Glad to hear that the diagram was helpful! Please do let us know how it works out.
by the way, where are you guys headed? I'm a tractor salesman by day and traveling musician by night.....I might be somewhere near you guys in the future. I googled your name but couldn't find anything on the web.
/ 6000 PTO lever #9
convert
Would you be so kind as to forward the images to me. And thank you in advance
/ 6000 PTO lever #10
I was unable to download or view the diagram that you sent to Bethpage Circus
2012 KAUFMAN PAVER DELUXE PINTLE HITCH TRAILEF (A67714)
2012 KAUFMAN PAVER...
2018 Autocar ACX Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2018 Autocar ACX...
2016 FORD F450 CREW CAB SERVICE TRUCK (A69167)
2016 FORD F450...
CAT C1.1 LITER WITH GEN END (CONDITION UNKNOWN) (A68842)
CAT C1.1 LITER...
2014 FREIGHTLINER CORONADO 122 SD (A67714)
2014 FREIGHTLINER...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
