M59 capabilities
/ M59 capabilities #1
Doug Sinjem
La Habra Heights, CA
I made my first post last week regarding purchasing an L39. Well was at the dealer today and was checking out an M59. It looks to have the same same front bucket and gannon rear scrapper as a full size skip loader. A full size skip weighs in about #14,000 where the kubota comes in around #8,300. I'm just wondering how the loader and gannon are going to perform on the smaller kubota? When you first look at the tractor, they look big, but the tractor is smaller than a full size but then when I saw the front bucket and the gannon scapper of to the side they looked huge. Anybody have thoughts on this?
Doug
/ M59 capabilities #2
If you look up the specs of a JD 310, the dimension are very close to the M59. The big difference is the weight of the M59 at #8300 and the 310 is about #18000, and the lifting capacities are about half on the M59.
I would think that the loader and backhoe on the M59 are a good match for it. It should be able to push itself around while digging and it is a capable tractor, but it is still no full-size backhoe. All around it is a nice do-it-all tractor, but for the price you could buy a 3000 hr full-size backhoe and a new MX5100 with loader and have much more capability yet.
/ M59 capabilities
That's exactly what I thought when I saw the M 59s buckets...but the weight becomes a huge factor when you step up to full size and plays a big part in moving them from job to job.
Doug
/ M59 capabilities #4
For the price of the M59 you could fine a good used full-size TLB with a lot less than 3000 hours. The M59 sure is a nice rig, though! :cool:
/ M59 capabilities #5
pricewise you can get a terex tlb w/ cab and amenities for close to the price of a M59. my backhoe weighs in around 9300 lbs. i am easily able to pull the machine or push when digging in heavy material with a 24" bucket. i would have to think this would be more noticible in lighter the M59. i'm going to give them a bit more time and see what the reviews look like for it. hopefully a cab will be offered in the future. this would add some weight. has kubota said anything in regard to filling the tires?
/ M59 capabilities #6
Could you use the Terex as a tractor also? That is what a lot of people are looking for. One unit, That covers everything.
I know when I get A TLB, It had to be a Tractor and Backhoe.
Pete
/ M59 capabilities #7
I've found the m59 loader is strong, but not too strong. I do have almost 2000 pounds weight in the tires.
And why m59 over used TLB? Covered that in an other post, but I wanted both tractor and backhoe, and didn't want to deal with the maintenance on a 3k hour backhoe. I've had great luck with kubota so far maintenance wise.
I've found the m59 strong enough for anything I've tried so far, been really pleased. And that includes light bulldozing with the 4n1
I can also use any skidsteer attachment (regular flow) with the m59, don't think you can do that with a TLB. My preseeder works great on the front.
/ M59 capabilities
Pete
The terex weighs almost twice the M59 which makes transporting more difficult
Doug
/ M59 capabilities #9
Doug
Yes I know that. Was just trying to make a point to the above post. That the M59 is more for people like me. That are looking for a TLB. To be able to replace a Trackhoe and then Kubota M4700 that I have. This way I have one unit. And one trip to where I am working.
Pete
/ M59 capabilities #10
IMHO this applies to both the L39 and especially the M59:
The machines could use more steel, In the case of the L-39 about 1000 Lbs worth and in the case of the M-59 about a tonne. A minimum 12.5 x 16.5 skidsteer front tire with HD Front axle would help the machines in soft ground.
Cab option for both also.
I know weight is an issue, both being too heavy to tow or too light to do heavy ground engagement.
/ M59 capabilities #11
If you want the weight, you can always add ballast. There is no need for that weight in structural steel. Having this on every machine would only be problematic for us. Infact, I think you'd find many more people wanting their M59 lighter than heavier.
/ M59 capabilities #12
One of the perks of this business is the ability to play with all these fine toys! I've seen units to light, you can add weight! I've seen units built to heavy, your stuck with a dog!
The one thing that these units were built for is to be able to be trailered without a large truck and the aggrivation along with the extra costs. They give people the reach they need, they will carry a decent load, and they are very flexible with attachments that other units can't carry.
There is no one machine that is right for everyone!!!!
/ M59 capabilities #14
and I love the tire ballast on mine. Its nice to have options - if it were built to my specs, it'd be too heavy for Chato.
The cab would be a really nice option, especially if "convertible" so I could let the breeze in when I wanted. I'm guessing the combination of the cab, swing seat, and removable backhoe is tough to engineer.
/ M59 capabilities #15
A JD 210LE or the Case 570 skips weigh in at around 14.000 pounds. That requires a truck, not a pick up, and capable trailer to transport. Weight and hydraulic capability is what you look for in a good TLB or a TL. The M59 is a good tractor for what it is. You can put it on a trailer and pull it behind your 3/4 ton or a one ton pick up. You can't with a real construction tractor.
When you look at the big stuff, the 210LE has about 8 or 9000 pounds of FEL brake out force and a lot more lift capacity than the M59. They are heavy steel real construction tractors. We are talking about two completely different animals here. For the hobbiest or a guy who does light construction work the M59 would work okay. But if you want to move a lot of dirt, or dig large holes quick, you have to step up to a real construction tractor. The 210LE is around $56,000.00 OTD. The Case 570 is about the same. The backhoes are about $20,000.00 more than a skip. It's all relevent.
/ M59 capabilities
This is a good observation, just depends on what you are needing the tractor for. Out here in CA I have seen 1 ton duallys pulling full size skips. I'm assuming they are overweight. I'm not sure what the rating on some of the new duallys are.
Doug
/ M59 capabilities #17
My dealer said the M59 has went up close to $6,000 since I bought it.
/ M59 capabilities #18
Really? If you dont mind me asking what did you pay for yours? I have been looking hard at the M59 for a while but there is no way I would pay an additional 6K for one...
/ M59 capabilities #19
No, I don't mind. I paid $42,500 with 3 point hitch and the rear hydraulics for the backhoe thumb. In all fairness he may have priced it to cheap to begin with. I have since added the thumb, front 3rd function hydraulic, tool box and rear remotes. Oh I fogot that included delivery two and a half hrs one way
/ M59 capabilities #20
Here's a cab solution
Sims Cab Depot - Kubota Loader/Backhoe Cab Enclosure - Models: M59
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
Gasoline Concrete Mixer, Honda 8.0 Engine  (A62679)
Gasoline Concrete...
2013 JCB 506-36 TELESCOPIC FORLKLIFT (A65053)
2013 JCB 506-36...
John Deere RM 12R Cultivator (A66285)
John Deere RM 12R...
2022 FORD F-450XL FLATBED TRUCK (A64277)
2022 FORD F-450XL...
