SnowPlow test #1
/ SnowPlow test #1 #21
Is there a heated cab next in your plans?
Since the front blade works so great, can I have your hydraulic rear blade? :rolleyes:
/ SnowPlow test #1 #22
Oops. Picked the wrong smiley face to beg with. :eek:
/ SnowPlow test #1
I think you used the right face to begin with!! :D
Man, I would love a heated cab, but in maryland it's like overkill, I think.
It would be nice when plowing, but, have a hard time justifying it for a hand full of snowstorms.
Actually, my RGB can be offset, a good 12" to either side.
4 bolts, and it's moved.
SO, I am thinking next time we get a more serious snow, I may shift it to one side which would add some usable width to the clearing ability.
/ SnowPlow test #1 #24
There is no such thing as overkill:D
Seriously though a cab is pretty nice almost anytime
Ken
/ SnowPlow test #1 #25
hayden said:
That's not a snow plow - it's a Zamboni
Beautiful job!
Exactly what I was thinking. I have to rig up something like that to plow off my son's hockey rink. This should be fantastic.
/ SnowPlow test #1 #26
here is a picture of the polypropelene board attached to the snow plow to avoid scraping the pavement
/ SnowPlow test #1 #27
Skunkwerx
How thick of a piece did you go with? How did you cut the material? (with a circular saw???)
/ SnowPlow test #1 #29
bx24 said:
Skunkwerx
What works for me is sandwiching it between 2 scrap pieces of thin plywood , paneling or osb and sawing through the wood and material with a jig saw.
O saw should work 2.
== L B ==
/ SnowPlow test #1 #30
LBrown59 said:
;)Air Conditioning works better with a cab.:)
I don't care what ya call it along as it stays between 69 and 72*f in there.
Actually once you put the "fish bowl" around you, you will want both. The summer sun is pretty strong even up here.
Ken
/ SnowPlow test #1 #31
Nice! Too bad shipping is twice the cost of the material for me :( Not that I would need it for a snowplow.. but looks good to put a skirt on my rough cut mower.
/ SnowPlow test #1 #32
:) See if you can find a scrap pick up bed mat
and cut what you need out of that.:cool:
I have bought new bed mats at big lots for 25 bucks. :)
== L B ==
/ SnowPlow test #1
bx24 said:
Skunkwerx
The stuff I got was 3/8" thick. It has fiber cords embedded.
I used a fresh utility knife and just kept scoring. I got to the point it would bend with a crease, like cardboard, then finished by slicing down the crease on the backside.
I don't think I would use a circular saw it might grab harshly, I think I would try a jig saw with one of those knife style blades installed.
If I was dealing with 1/2" or thicker material, I would probably run it through my bandsaw.
Bottom line, it wasn't a huge problem using the utility knife.
/ SnowPlow test #1 #34
Has anybody found a good source for nylon strips? I guess some of the other polymers and plastics may be good as well, if they are tough enough and cheap enough. You would think there would be a good surplus source.
jmf
/ SnowPlow test #1 #35
Since I live in the "sunny" south I don't have your needs but a suggestion from the time we had a breeding kennel. I cut down truck flaps to make the dog doors as the longest lasting material I could find. A band saw was the perfect tool for the job. It cut cleanly and quickly. For the thick stuff you would probably want a 3/4" blade, 4-6 teeth per inch.
Vernon
/ SnowPlow test #1 #37
SkunkWerX,
Do you have the seller's name on ebay where you bought the rubber strip? The link you had posted last year is no longer valid and I didn't have any success doing a search on ebay.
Thanks.
/ SnowPlow test #1 #38
SkunkWerX,
Thanks.
I can't help you with the email address. Have you thought about flat drive belting? TSC sells belting by the foot.
/ SnowPlow test #1 #39
I will check that out. I also read that TSC has some horse matting that can work. I'll have to go see what they have.
Thanks.
Tater Squeeze Chute (A61166)
Tater Squeeze...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A62130)
UNUSED SWICT 66"...
New/Unused Landhonor 20,000lb Electric Winch (A61166)
New/Unused...
2020 John Deere 6120M (A62180)
2020 John Deere...
Wooden Wagon Wheel Table (A61569)
Wooden Wagon Wheel...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
