SnowPlow test #1
/ SnowPlow test #1 #21
Is there a heated cab next in your plans?
Since the front blade works so great, can I have your hydraulic rear blade? :rolleyes:
/ SnowPlow test #1 #22
Oops. Picked the wrong smiley face to beg with. :eek:
/ SnowPlow test #1
I think you used the right face to begin with!! :D
Man, I would love a heated cab, but in maryland it's like overkill, I think.
It would be nice when plowing, but, have a hard time justifying it for a hand full of snowstorms.
Actually, my RGB can be offset, a good 12" to either side.
4 bolts, and it's moved.
SO, I am thinking next time we get a more serious snow, I may shift it to one side which would add some usable width to the clearing ability.
/ SnowPlow test #1 #24
There is no such thing as overkill:D
Seriously though a cab is pretty nice almost anytime
Ken
/ SnowPlow test #1 #25
hayden said:
That's not a snow plow - it's a Zamboni
Beautiful job!
Exactly what I was thinking. I have to rig up something like that to plow off my son's hockey rink. This should be fantastic.
/ SnowPlow test #1 #26
here is a picture of the polypropelene board attached to the snow plow to avoid scraping the pavement
/ SnowPlow test #1 #27
Skunkwerx
How thick of a piece did you go with? How did you cut the material? (with a circular saw???)
/ SnowPlow test #1 #29
bx24 said:
Skunkwerx
What works for me is sandwiching it between 2 scrap pieces of thin plywood , paneling or osb and sawing through the wood and material with a jig saw.
O saw should work 2.
== L B ==
/ SnowPlow test #1 #30
LBrown59 said:
;)Air Conditioning works better with a cab.:)
I don't care what ya call it along as it stays between 69 and 72*f in there.
Actually once you put the "fish bowl" around you, you will want both. The summer sun is pretty strong even up here.
Ken
/ SnowPlow test #1 #31
Nice! Too bad shipping is twice the cost of the material for me :( Not that I would need it for a snowplow.. but looks good to put a skirt on my rough cut mower.
/ SnowPlow test #1 #32
:) See if you can find a scrap pick up bed mat
and cut what you need out of that.:cool:
I have bought new bed mats at big lots for 25 bucks. :)
== L B ==
/ SnowPlow test #1
bx24 said:
Skunkwerx
The stuff I got was 3/8" thick. It has fiber cords embedded.
I used a fresh utility knife and just kept scoring. I got to the point it would bend with a crease, like cardboard, then finished by slicing down the crease on the backside.
I don't think I would use a circular saw it might grab harshly, I think I would try a jig saw with one of those knife style blades installed.
If I was dealing with 1/2" or thicker material, I would probably run it through my bandsaw.
Bottom line, it wasn't a huge problem using the utility knife.
/ SnowPlow test #1 #34
Has anybody found a good source for nylon strips? I guess some of the other polymers and plastics may be good as well, if they are tough enough and cheap enough. You would think there would be a good surplus source.
jmf
/ SnowPlow test #1 #35
Since I live in the "sunny" south I don't have your needs but a suggestion from the time we had a breeding kennel. I cut down truck flaps to make the dog doors as the longest lasting material I could find. A band saw was the perfect tool for the job. It cut cleanly and quickly. For the thick stuff you would probably want a 3/4" blade, 4-6 teeth per inch.
Vernon
/ SnowPlow test #1 #37
SkunkWerX,
Do you have the seller's name on ebay where you bought the rubber strip? The link you had posted last year is no longer valid and I didn't have any success doing a search on ebay.
Thanks.
/ SnowPlow test #1 #38
SkunkWerX,
Thanks.
I can't help you with the email address. Have you thought about flat drive belting? TSC sells belting by the foot.
/ SnowPlow test #1 #39
I will check that out. I also read that TSC has some horse matting that can work. I'll have to go see what they have.
Thanks.
2017 Mitsubishi Mirage G4 Sedan (A61569)
2017 Mitsubishi...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A61166)
New/Unused...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
207277 (A52708)
207277 (A52708)
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
PAIR OF DIAMOND PLATE DBL AXLE FENDERS (A62130)
PAIR OF DIAMOND...
