Switch from pin on to quick change
/ Switch from pin on to quick change #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
How costly is this to do?
For example, If a JD 5210 series has a 541 loader with a pin on bucket, what is the difficulty & cost to switch to a quick attach on the loader arms?
/ Switch from pin on to quick change #2
for reference, for kubota I got one from ATI - around $600 as I recall. I'd bet they do JD as well, and can't imagine the price would be hugely different (adjusting for iron price raises)
I bet JD might do it as well with a standard piece.
So this is just a matter of buying a bolt on bracket or set of brackets for the ends of the loader arms that have the quick connect pins mounted in them?
/ Switch from pin on to quick change #4
Yes, but you will need to either mod your bucket or buy another with the QA receiver to match the bracket mount on the loader.
larry
larry
Yeah thanks, I realized that, too. Just happens that I'm looking at a grapple bucket anyway, so the GP pin on bucket would prolly get sold. My CASE has an FFC quick attach, which is a little different and it was pricey to add, but i guess that's because it's a lot bigger piece of iron.
/ Switch from pin on to quick change #6
I think you have to add a "Bumper" or stop to keep the bucket from dropping to far at full dump. If I was considering a change I would talk to someone in service at a dealership or look at a model with the quick attach and determine if a bumper or stop is need.
