Mowing BX2350 mowing newbe
   / BX2350 mowing newbe #21
1*Off hand I'd say that all wheel steer would definitely make it more maneuverable but,
2* I don't think that you could add all wheel steer to a BX size tractor. The weight lifting capacity alone of the 3ph would be too much for the mechanism to effectively support, at least affordably
1* wonder if aws really makes that much difference and is it actually worth hundred/thousands of $s more to get it. ?
2*so then aws is not nearly as heavy dutty .rite?
   / BX2350 mowing newbe #22
1*If you adj the wheels with the knob set at that position you wil have to reset the wheels every time you want to mow at a different hight.
Also you don't set the wheels below the deck .
The wheels are supposed to be set above the surface/ground.
Huh? If the wheels are above the deck lip, what's the point in having them? They wouldn't serve a purpose or ever help keep the deck from jamming into the ground.:confused: Am I missing something? Seriously, I don't understand that concept. I know that you don't want the wheels actually running on the ground all the time, they're just supposed to be there for those high spots in the yard.
I keep my wheels about 1/2 below the mower deck, and never adjust them if I cut higher, only if I cut lower. ANd I tend to cut about 3 1/2 inches high.
   / BX2350 mowing newbe #23
It might help you from feeling so beat up when the cutting is done. You can find them at any motorcycle shop that has dirtbike gear - $20.
'Frank
You should not need such a thing just to mow yer grass.
I say slow the tractor down to under 90 MPH and smooth out the lawn!!!
   / BX2350 mowing newbe #24
Huh?
1*If the wheels are above the deck lip, what's the point in having them?
2*Am I missing something?
3*I keep my wheels about 1/2 below the mower deck, and never adjust them if I cut higher, only if I cut lower.
1*I didn't say anything about setting the wheels above the deck lip.
2*Yeah you missed the part where I stated the wheels are supposed to be set 1/4'' to 1/2'' above the service.
Note That's surface not deck lip.
3*Again the manual is talking about the space between the wheel and the ground.
It's not referring to the distance between the wheel and the deck
   / BX2350 mowing newbe #25
   / BX2350 mowing newbe #26
I guess I got mixed up on what you said in your earlier post. "Also you don't set the wheels below the deck ." I thought you was referring to the mower deck.
Oh well, I guess I was having one of those moments.
Thanks.
   / BX2350 mowing newbe #27
3) Proper air pressure. No matter what psi you run the tires, makes sure that the two fronts are exactly the same as well as the two backs.
I run mine approx 3 psi lower in the rears inorder to cushion the bouncing and this does pretty good. Course I had to compensate for this in the MMM setup but it wasn't too much of an adjustment.
Volfandt, Nice over view on the mower success suggestions but I wanted to pick you brain on #3. Factory suggested pressure settings on my bar's are 22/17 respectively. So your running 19/14?
I had 17/16 in last year and I got into trouble with heavy loads and the FEL but the mowing was reasonable. At my 50hr service, my dealer set the pressures back to 22/17 and mowing the lawn is beating the stuffing out of me. Since I'm not wild about changing the pressure in the filled rears all the time I think of going with a 18/14 and just running the front (unfilled) up to 22 when I do FEL work. Any thoughts.
   / BX2350 mowing newbe #28
I'm running 14 in the rears and 22 in the fronts. Like you, I had discovered the fronts don't handle heavy FEL work when run lower.
I ran bars for the 1st two yrs then found a great deal on a set of turfs and changed over to them. I'm on my 2nd mowing season on them and they are much easier on my turf & rear :D
I decided to keep the bars tho, if I ever get into some extended dirt work they'll come in handy and will probably keep the resale value up should I ever upgrade to a larger machine. Those bars do make the machine look more aggressive :D
   / BX2350 mowing newbe #29
My manual has the turfs running lower pressures that the Bar's or AG's. I will give the 18/14 a go. Thanks for the help
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
Sterling 9500 (A55315)
John Deere 4510 (A53317)
John Deere 4510...
Zero Turn Mower (A55853)
Zero Turn Mower...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
