DIY Home built compact tractor
/ DIY Home built compact tractor #221
john_bud said:
More $$, but easier!
easily spending $$ isnt the idea of building a tractor, if it was he'd buy a brand new one at a dealer, thats easiest and most $$ ;)
/ DIY Home built compact tractor #222
GT2, I've been meaning to post this, but... Anyway, I was on my JD4400 last week & checked the steering. It goes 3.75 turns lock to lock.
/ DIY Home built compact tractor #223
GT2 said:
Believe me I racked my brain trying to figure how to do that.
I would have had to design a complicated set of shafts and universal joints to get over/around the engine and in the end all that stuff would have been in the way anytime I wanted to work on the engine.
Thats my story and I'm stickin to it!:D
Good story! I'll buy it. ;)
I got my CV flange to universal joint flange adapters made today, their held in by two temporary bolts till I get the proper fastners.
Top and bottom view ( the shiney disks)
Bottom view of the front and rear drive lines
/ DIY Home built compact tractor #227
Just cought this post. AWSOME job!!!!!!!!!!
/ DIY Home built compact tractor #228
I've worked on several Samurai based rock crawlers so this has definitely been an interesting read for me. Your metal work looks really nice.
I am a little concerned about the durability of the axles for this application though. The factory Sami 1.3L carb motor put out about 66 hp and 76 ft-lbs of torque. The axles have 3.73 gears in them. The front axles have itty bitty little birfield joints in them that are just a little larger than a baseball. With diff lockers, you can safely run about 31" tires, but still shouldn't get after it with the front wheels turned hard left or right.
Now you are talking about running a motor with more torque and tires with more traction.
The cheapest, most expedient solution for front axle strength is birfield rings. They are relatively cheap alloy rings that press fit over the birfield joints to keep them from exploding. Unfortunately, you have to remove the steering knuckles to install them. The factory birfields fit through the knuckles; with birf rings they don't. You can also get complete alloy chrome moly shafts, but they are really hard on the wallet.
I think that possibly the best solution might be to consider finding a set of '79-85 Toyota Pickup or 4Runner axles. They have the strength of a Dana 44 or better, come with factory 4:10 gears, and still have the removable 3rd member.
I'm also a little concerned about the steep compound angle of your front driveshaft. Definitely a non-starter for a road vehicle, but maybe fine for 10 mph.
The best of luck and keep us updated.
/ DIY Home built compact tractor #230
very interesting. Where do you find the time?? Can't wait to see this thing in action
Its hard to find the time lately, I've got a lot of irons on the fire.
I'm presently working on the diesel engine, trying to get it running. I want to do a test drive befor any further fab work, to make sure the ratios and ground speed are going to be acceptable.
Tim
GCLnIndiana said:
How did the test drive work out?
Hasent happened yet. I tested the injectors yesterday, 2 good 1 dribbles & 1 clogged.
I'm going to see if the wrecking yard has any cheap, or I might rebuild them.
Tim
/ DIY Home built compact tractor #235
Just found this post - amazing talent you have!! Any more updates and more pictures???
/ DIY Home built compact tractor #236
need an overall shot.
/ DIY Home built compact tractor #238
Great thread, I also joined because of this. I've been kicking around the idea of building a compact/garden tractor, not quite as ambitious as this but 2wd and around 10 hp.
I used to compete in the tractor pulls with my 4-H club as a kid, with a Garden Master tractor. They had used cut down car parts and a 9hp Briggs to build a small tractor. Managed to pull 5400 lbs with it once. Figured copying it a bit and a more modern engine (the one I used to use was a hand crank, which my dad converted to a loose rope pull start) and newer drivetrain would be a pretty useful machine.
Can't wait to see this one going, are there any more threads on home built tractors?
Thanks,
James
/ DIY Home built compact tractor #239
Tim
Excellent thread. Keep us posted. Can't wait to hear it run.
While you have it apart, I would change the timing belt, real cheap insurance.
What is next, a bio diesel set up??
Will
/ DIY Home built compact tractor #240
With Volkswagen Diesel engines, there is also the small belt on the other end of the crankshaft that drives the fuel pump... I think it has twice the rated life of the main belt (probably because its less risky if it breaks)
But for the secondary belt, a visual inspection (check for rags) should be safe enough.
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
