FORD 4000 Not Charging
/ FORD 4000 Not Charging #1
number two
Northern Lower Michigan
Kubota B3030HSDC Kubota L2501HST
A friends Ford 1966 4000(actually a 4101 model) has the charging system warning lamp on and a voltage check at the battery shows 12.5 volts at 1500 RPM-obviously not charging. I'm hoping someone could help me with troubleshooting suggestions. It's been just too long since I've worked with a generator and regulator system,and can't even remember how to polarize the system.
I've got the I&T service manual with the starting/chaging system wiring diagram,but no instructions.I have the usual tools-DVOM,test light,load tester,Power Probe. Just lacking a direction. Any advice appreciated as always.
/ FORD 4000 Not Charging #2
Check voltage regulator; it may be the culprit.
/ FORD 4000 Not Charging #3
I'm supporting dqdave1's suggestion.
The voltage regulator on your tractor is almost certainly mechanical unless they made a solid-state replacement and someone installed that in recent years.
Find your regulator by looking in that service manual, or by tracing the wire (probably moderatly heavy gauge) from the generator toward the battery.
Those regulators worked kind of like a normally-closed relay. The voltage from the generator was applied to the coil in the relay. When the voltage got too high, the relay clicked shut, opening the circuit which charges the battery.
I vaguely remember bending contacts in those regulators to adjust them, but it sounds like your regulator has failed completely (i.e., the relay is always open, so no charging current reaches the battery).
If you're adventurous, you might take advantage of the fact that this thing is mechanical and you can see how it works. Open it up (probably has a metal cover and you can pry up the tabs) and check for a broken lead to a coil. There's nothing quite as satisfying as taking the long chance to fix something and then succeeding. Well, almost nothing.
/ FORD 4000 Not Charging #4
I agree the prime suspect is the regulator but you can eliminate the generator as the problem and check the regulator with a quick test.
There should be an "F" terminal on the generator and the regulator. This is the Field winding connection. The field winding controls how much current the generator is to output to the BAT terminal. In simple terms, the regulator applies voltage to the field to produce current at the BAT terminal.
Attach a volt meter on the battery terminals. Get a 5-10W ~1-2 ohm resister. (An ignition resistor is ideal and available at most auto parts or Radio Shack) Attach the resistor in series with a piece of 14ga. wire. Attach one end of the wire to the + post of the battery (- post if positive ground system) and with the engine running, touch the other end to the Field terminal on the generator. If you don't see an increase at the battery, the generator is bad.
Otherwise, check for loose connections on the Field wire from the gen to VR and/or the "I" wire from keyswitch (or starter I post) to the VR. With the key on, you should have voltage at the "I" terminal of the regulator. If you have battery voltage at the I terminal an nothing or low (< than ~8v) on the F terminal, replace the regulator.
Don't try to bypas the regulator by leaving the test wire connected to the Field terminal. You can boil a battery is short order.
/ FORD 4000 Not Charging #5
Attach a volt meter on the battery terminals. Get a 5-10W ~1-2 ohm resister. (An ignition resistor is ideal and available at most auto parts or Radio Shack) Attach the resistor in series with a piece of 14ga. wire. Attach one end of the wire to the + post of the battery (- post if positive ground system) and with the engine running, touch the other end to the Field terminal on the generator. If you don't see an increase at the battery, the generator is bad. .
I'm sorry.. but that is just plain bad / incorrect advice. there are at least 3 other problems other than 'generator is bad' that your test completely overlooks.
soundguy
/ FORD 4000 Not Charging #6
Ok.. that is a 12v, negative ground, B-circuit generator and regulator system, that uses a lucas generator and regulator.
here are a couple tests to do to check out components:
First.. polarize the system... jumper bat to field for a couple seconds.
Motor test: slip the belt off the genny, jump bat to armature, and bat to field.. genny should spin.. most gennies that motor will charge.. most gennies that charge, will motor.
Next, slip belt back on, put volt meter on battery.. start tractor, get to 1000rpm.. if charge lamp don't go out / volt meter don't come up, jumper bat to field... if still nothing, then jumper bat to arm as well.. if charge comes up, regualtor is bad.
new regulator is available at CNH dealer... I just put one on my 5000.. ( same regulator / genny ).. has a couple keyed connectors on it.. so it's ahrd to plug up wrong.
If it does turn out to be the genny, they usually don't cost much mor ethan about 80$ to fully rebuild.. and not much more to get a replacement.. my local store has the 'will-fit' repalcements for 89$ plus core swap. Field connector is a couple inches over.. but it all mates up.. just swap over your tach drive and go..
soundguy
Gentlemen,thank you for all the replies.You've helped me a great deal getting up to speed on these older systems.Extra thanks to Soundguy for the troubleshooting sequence and polarizing info.Naturally I suspect the regulator but I just hate changing parts without diagnosis first. Back when I was driving generator stuff,I wasn't that good a tech and was a parts changer.I will be over there to perform the tests in the next week and if you like,I'll post back. May even have more questions. An additional thought,after the yet to be determined repair,I believe I will need to polarize again before hooking up the battery cable?Thank again.
Oh yeah Egon,I've always remembered those Lucas "Father of Darkness" tales. And Iron Horse,this guy isn't going to want an alternator conversion,but it makes good sense to me.In the old days,I believe the Delco 27SI was the popular conversion alternator? Many tanks again.
/ FORD 4000 Not Charging #11
Get a 1 wire alternator off a car and fix it forever .
That would work if he didn't want a tachometer, which is driven off the generator!
OR, he has to buy a NEW dash cluster, and an aux tach drive.. wich is way more $$ than just fixing his generator / regulator.
OR he has to get a delco 10DN alternator with a tach drive and buy an external regulator for thAT 10dn, which again, is more $$ than just fixing his generator and regulator.
For about 120$ and 10 minutes of wrenching he can go in with a new genny and regulator.. if he only needs a rebuilt genny or just a new reg.. the price drops drastically.
soundguy
/ FORD 4000 Not Charging #12
I think you got a few things backwards... the battery cables HAVE to be hooked up PRIOR to polarizing... remember.. moving electrons make magnetic fields..
soundguy
/ FORD 4000 Not Charging #13
I would think the delco 10DN would be a more common repalcement as it has the tach drive,,
though a 10SI or 12SI is fine.. in fact.. anything you can make brackets for should charge the battery if the tach wasn't an option.. just get it wired correctly.. I helped a buddy drop a CS-130 into a tractor a while back.. no biggie.. just had to figure out what resistance range it wanted inthe excite line..
soundguy
/ FORD 4000 Not Charging #14
Had the same problem about six or seven months ago. I went here Voltage Regulator & Cut-out and got a new regulator. But mine was obviously broke. One of the terminals had corroded through. The regulator is located on the firewall next to the battery. Or would have be behind the battery.
Wedge
/ FORD 4000 Not Charging #15
If it was recently working, a few bangs on the regulator might work. If starts working you can replace it later. This'll free up the contacts if they are stuck.
/ FORD 4000 Not Charging #16
Lucas regs are notorious for sticking. the lucas gennies are actually fairly robust.. but the regs are their main problem.
soundguy
Thank you again for all the suggestions and tutoring,especially Soundguy. I have to make time to visit this tractor today. Ever since I changed his oil and filter,I have this recurring oil leak at the oil filter to block seal. Either the bolt on the canister is loosening up or the gasket is compressing,or something. It started leaking big time after a couple months,so I got a new filter kit and replaced the filter again. Now a week later it's leaking again,as in like a quart right now. How can a simple oil change turn into this. Amazing!
/ FORD 4000 Not Charging #18
Does this have the spin on filter, or the cartridge filter ( sounds like the cartridge filter )... if so, remove it.. and make sure there are no bits of the old gasket left on the block and the canister, and make sure you have a small gasket under the hold down bolt.. even gasket paper or a nylon oil plug gasket will work..
soundguy
Yes,it's the cartridge style,and the bolt was tight and it still leaked some at the block to housing gasket. Went to the dealer and got a Genuine NH filter/gasket kit. Will try again tomorrow. Dealer had the voltage regulator @$48 in stock. Yes,I was using the rigid fiber washer under the bolt. Dealer is ordering a spin-on filter adapter that hopefully will work for us. $28 plus shipping. I would like to think that would end this foolishness. Can you imagine how humbling an experience this is? I can't even seem to do an oil change! We'll give it another try tomorrow. Can't give up. Thanks.
/ FORD 4000 Not Charging #20
I actually like the cartridge style filter better due tot he thick heavy can being very puncture proof.. however.. the convienience of a spin on is hard to argue with.
soundguy
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
525 GAL WATER TANK (A68842)
525 GAL WATER TANK...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
PALLET OF ANCHORS (A68842)
PALLET OF ANCHORS...
Unused 2021 Berti 112in. Handy 230-280 Hydraulic Flair Mower Tractor Attachment (A66734)
Unused 2021 Berti...
