Clamp On Bucket Forks
/ Clamp On Bucket Forks #1
mjfox6
NE Mississippi
2005 Kubota L3400 HST
I've wanted some clamp on bucket forks for quite a while. In fact, I joined TBN so that I could send a PM to Madreferee and get his plans for building a set. A year later I decided to make it happen. I researched companies online and read lots of info on TBN to find out why people were unhappy. I thought about buying a set, but I could not find a set that employed more than one clamping mechanism. Also, for the price they want, I was sure I could fabricate a set cheaper (I'm scared to add it up, but I don't think I saved very much!).
Thanks to Madreferee for his initial plan wherever he may be. Some major redesign and lots of hours of fabrication and here is what I ended up making...
/ Clamp On Bucket Forks #2
Very nice!
Any problems with keeping them straight?
I heard others complaining that the clamp on style would angle from side to side if you put any side load on them.
/ Clamp On Bucket Forks #3
Those look really good. Maybe this winter I'll get around to making a set.
What did you use for the T-handle bolts?
Vic
Zick said:
Very nice!
That was the major complaint that I saw, that is why I used two clamps. I grabbed the tips and shook them back and forth without them moving. It's a major advantage over the one clamp version everyone sells. Wonder how long before someone sells a two clamp version now? Tell them to send me a check! :)
Vic
I tried to keep the number of materials to as few as possible. That meant I had 1" rod (where the lip of the bucket clamps), so I used that as the handle. I wanted 1" all-thread to match, but decided to go ahead and spend the extra money (and it was A LOT extra) and buy ACME threaded rod. It works better in dirty environments.
bialecki said:
Madreferee passed away I think last April 07, many on this site have missed him.
That's why I said, "wherever he may be." I just wanted people that knew him to know I used his basic design and joined TBN because he offered it to everyone that wanted it.
/ Clamp On Bucket Forks #8
Great design! I like how you are able to leave the toothbar in place.
/ Clamp On Bucket Forks #9
Somewhere out there, Madreferee is smiling. Nice job!:)
/ Clamp On Bucket Forks #10
Zick said:
Very nice!
they can do that but it's not a big problem most time.
/ Clamp On Bucket Forks #11
Did you get the "Acme" threaded rod from your local steel supplier or what was your source? And What is the female portion for the rod. Gene
The acme rod and the nuts (welded to the channel) were both from McMaster-Carr.
/ Clamp On Bucket Forks #13
Yeah cause moving something to the side with the forks and then having one of your forks crooked makes it so easy to pick up the next thing. :rolleyes:
/ Clamp On Bucket Forks #14
Really nice job. I wanted to build a set myself but did not have time and purchased a set of Paynes clamp on forks. The double clamp should help keep the forks straight never thought about that approach. I was going to attempt to increase the contact area where the fork fits to the cutting edge. My thinking was if I could lengthen this contact area the forks would be less likely to move...
/ Clamp On Bucket Forks #16
On a scale of 1-10 how annoying do you find this movement?
With me It's 1 maybe less.
/ Clamp On Bucket Forks #17
I use my bucket fork all the time. Some times they move and most of the time it in never a problem. I have regular forklifts at work and I get on and off them more to slide the forks around than I do on my tractor
/ Clamp On Bucket Forks #18
As long as I approached what ever I am picking up straight it was not that big of a problem.. Maybe I am not as skilled as you but I would rate it ~4 or so.
Giving it more thought the lack of seeing the forks is probably more of an issue. I mostly use my clamp on forks for loads like this:
They work great for trimming/removing. Larger heavier items go into the bucket, the big bushy stuff lays across the clamp ons
If I am actually moving pallets or heavy loads I get out my QA pallet forks.
/ Clamp On Bucket Forks #19
One way to keep them from moving would be to weld a small piece of pipe to them horizontal on the backer plate, and then have a smaller diameter pipe that would slide through the pieces. I use electrical conduit for mine and that worked well.
/ Clamp On Bucket Forks #20
Love This Site.. enjoy sharing some of my experience and ideas...
Here's my custom bucket fork attachment, simple quick connect and welded on chain hooks. easy to build... enjoy
NORCO MOBILE WHEEL WORK STATION (A63569)
NORCO MOBILE WHEEL...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63118)
2006 Cadillac GM...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
New Holland 565 Square Baler (A64047)
New Holland 565...
