Work Platform For FEL
/ Work Platform For FEL #1
GaryBDavis
Gold Member
Andice, Texas
I had this 4'x4' platform lying around that came off a staircase at a concrete plant and I decided to put it to good use. I cut holes to fit my pallet forks, added a railing and called it a work platform. There are anchors welded on each side for straps to hold the platform tight to the pallet forks back carriage and a safety was added chain for back up.
My FEL will lift the bottom of the platform to about 10 feet. Add me and my pole saw and I can now get limbs up to about 20 feet.
I know a FEL isn't design to lift people and I'll take hits from the safety police on this project, but it sure is safer than standing in the bucket while I trim trees.
/ Work Platform For FEL #2
Looks great gary, I've been wanting to make something like that for my boom pole in my gallery. I like yours be careful and alway have a good operator running the machine
Jim
/ Work Platform For FEL #3
I would take your setup any day. In subdivisons arond here you will see guys in a man basket (or a pallet) on the end of a forklift 30-40' in the air,on a side hill in 3' of mud. You have side rails, the basket is tied to the loader. You even have the helmit, face sheild, and ear protection. I get the ear protection right but thats about it when I cut wood. I think it's a good job, and a safe idea.
/ Work Platform For FEL #4
Gary I think you are right about the safety police having a caniption over this. I personally think you did a great job. I spent a lot of years in a steel mill working off of a similar basket to that only attached to a forklift. For everyone that says something bad about your setup I challenge them to point out where a ladder doing the same job is safer. I know the stock one is going to be that a ladder wont fall down if is placed properly. My reply to that is that you can fall off a ladder a lot easier than you can that platform.
/ Work Platform For FEL #5
That's pretty cool, Gary. I have seen metal pallets, but have never been fortunate enough to snag one or two. When I do get one, it will be on the welding list...
Just thinking about other applications...If you added a portable top and put skirting around it and a stool inside, you could have a portable deer stand! Of course, I'm not sure how you would get in and out if it were raised...
/ Work Platform For FEL #6
The safety police can leave you alone on that one, I have been in the basket on a forklift-many times and none were built as good as that. Tied to the tractor and even has non-skid floor. Great job, thank you for sharing.
/ Work Platform For FEL #7
I want to build one myself, as i think next year its time to do a major treecutting roundup again...
the only thing i would add to that, is an overhead rail to protect you from falling tree limbs after you cut them. branches tangled up high in the tree, can drop unpredictable. It also protects your tractor from treelimbs scratching the paint off while coming down..
/ Work Platform For FEL #9
Very nice! Found any more of those platforms lying around cluttering up the place? If you do, let me know. I'll haul it off.
/ Work Platform For FEL #10
Gary,
Very nice. My problem is that I do most things on my own and the idea of being up there with somebody else driving scares me. Obviously, I don't trust my choices of operators. LOL
My solution is to park the tractor and climb a ladder up to the bucket to have a working platfrom. Could you add a sliding ladder to the side of your platform so that you can work by yourself?
Eddie
/ Work Platform For FEL #11
I wouldn't worry about what someone else thinks, your rig looks good. A friend & I recently built a platform for mine and we trimmed over 200 trees in & around this pasture. My platform is made from treated 4x4's with 3/4" plywood floor and is 2' deep and 8' wide - 2 men with chainsaws had plenty of room to safely operate. I operated the tractor since I have the most experience with it, I knew what grades etc. we could safely handle etc. I have bolt-on forks on my older bucket that we attached the platform to, then ran long bolts thru the floor of the platform thru the 2 forks. Had a wooden toolbox that fit inside the bucket so the guys had storage for gas & tools etc. without cluttering the platform. We were able to trim up to about 16' - 18'. The landowner was extremely happy with the job and how quickly we got it done.
/ Work Platform For FEL #12
One saftey thought when using it is something that happened to a guy I know. He was trimming some branches on a tree while standing in the FEL. He was either not paying attention, or just didn't see the situation properly. He cut one particular branch that was under tension. It swung around and hit him hard enough to throw him about 20 feet off the FEL. He hit the ground hard and broke several ribs. All he remembers was cutting the branch, then a glimpse of it coming at him. Next thing he knows, he's in the hospital.
Eddie
/ Work Platform For FEL #13
American ingenuity at work again. Not sure what the safety police would complain about. I agree with most people here it's much safer and more stable than a ladder. As long as you counter balance the weight and don't exceed the load of the FEL whats unsafe about this thing. I had to rent one of tailer type lifts a few years back. Ya know all in one thing. Small 5 HP engine to drive the hydraulic, and three legs for stabilization. I had to go up about twenty feet and reach out maybe 5 or 6 feet. Once the thing quit swinging and swaying it wasn't too bad. But sure hated having to move the platform each time.
Wedge
/ Work Platform For FEL #14
I'm not the safety police, but I will speculate on the issue.....
The safety issue is a hydraulic leak, busted hose, etc. If a hose or fitting burst while working aloft, you would plummet fast, like gravity. if it was the dump circuit, your bucket would "dump" you.
Installing some pilot-operated check valves at the cylinders and it would remedy that possibility. Any hydraulic manlifts produced for the purpose of lifting a person aloft, must have a proper check valving system.
Always use plenty of rear ballast, too.
/ Work Platform For FEL #15
Nice Job!
Back in the 80's I worked in a Tool and Machine Shop... we were always using a forklift basket... I was only there a short time before it became my job to operate the Forklift Basket. It was a compliment because none of the guys would go up in the basket unless I was the operator.
They knew I was no-nonsense and was not into practical jokes on the shop floor. It also helped that I had a real steady hand at the controls.
We had to take an OSHA safety course and I learned that many on the job accidents were attributed to practical jokes and being in a hurry...
/ Work Platform For FEL #16
I tower climb on occasion and have to get recertified every couple of years. Part of it involves OSHA regs, etc. Jobwise, when you have to use a bucket, you have to be anchored into the bottom of the bucket.
Common sense wise...I think it would be a good idea to strap yourself onto the bottom of your platform. Make sure there is no slack in the line from your waist to the anchor. The guy that Eddie mentioned probably would not have fallen overboard if he was strapped in.
/ Work Platform For FEL #17
Another thing to watch out for is dropping things (branches?) down along the loader arms. Pretty easy for them to slide into the joystick & dump you on the ground.
Nice rig, nice design, I have no problems with it other than, as the rest, I want it....
--->Paul
/ Work Platform For FEL #18
I like it alot, it's the perfect size and that grip strut is the icing on the cake, I was gonna jerry rig one out of wood starting with a pallet, I know a guy that will sell me one of those factory fork lift man platforms, but he wants a ton of money and yours looks better IMO.
There is a real risk of falling out of it, but that can be mitigated with a simple harness and a lanyard connected to the forks super structure, either a full body harness and a lanyard with a slow stop shock absorber, that gives you more mobility or just a belt and a positioning lanyard that restricts mobility (so you couldn't fall out in the first place) like Redbug mentioned, but I would attach to the fork frame as opposed to the platform for obvious reasons.
That's what we do when working in these boom lift baskets, it'll make you feel more comfortable and more productive.
115 foot machine here, you could do some serious pruning with this thing.
This is about 90 ft off the ground looking over this 120 year old slate roof we maintain.
Harness
/ Work Platform For FEL #19
There is a real risk of falling out of it, but that can be mitigated with a simple harness and a lanyard connected to the forks super structure, either a full body harness and a lanyard with a slow stop shock absorber that gives you more mobility or just a belt and a positioning lanyard that restricts mobility (so you couldn't fall out in the first place) like Redbug mentioned, but I would attach to the fork frame as opposed to the platform for obvious reasons.
115 foot machine here,you could do some serious prunning with this thing.
Harness
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
2018 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2018 Nissan...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
