Leaking Gas Tank
/ Leaking Gas Tank #1
Stampeder
Gold Member
East Texas
Montana 4940C, FEL, Quick change 3 point factory hitch, pallet forks, grapple, 50 gal tank sprayer, Bush Hog PHD
The other day I was haying and as the diesel was running low in the tank I decided to head to the barn to fill up.
It was a usual day these days in Texas with the temp over the century mark.
Anyway as I was filling up I noticed that the diesel was coming out and creating a minor environmental disaster on the ground beneath the lower mounting bolts on the gas tank. A large bucket placed in timely fashion avoided any major problems.
However now I am faced with a problem with my 4940C, not to mention that I have half a hay field sitting there.
So, it was up on my neighbours trailer and the fifty mile hike down to Bullard Texas to the tractor hospital.
It turns out that this is not an uncommon failure. The owner of the dealership told me that he has replaced three tanks himself. The factory is out of stock and tanks and is air freighting a bunch in from Korea.
It seems that the tanks develop leaks in the plastic around the mounting bolts. I'm not sure if the temperature was a contributing factor or not but it poured out at a good rate.
My tractor is still under warranty so I'm not worried about the repair cost but the down time at this time is sure a big pain in the a&*.
While it's in the hospital it's getting a few other minor annoyances repaired, like a broken coffee cup holder.
Anyone else had this problem or heard of it.
Cheers.
Glenn.
/ Leaking Gas Tank #2
Glenn,
No problem like that here at all!!! My first thought was..God will getcha for threatening to tell my wife about the MP-3 player possibility!!! LMBO!!
/ Leaking Gas Tank #3
I wonder if it is an issue with rubbing or something around the mounting frame?
/ Leaking Gas Tank #4
Haven't seen any fuel leaks on mine, but may be developing an oil leak, will keep everyone informed. So far, so good, @625 HRS. I did destroy the boot for the remote valves while backing up, punched a Salmonberry stem about an inch through, about 3" from my right thigh, in 2 low. Didn't take a picture of the incident, but if anyone is interested, I had to cut the cane off with a handsaw, figuring to make a walking stick out of it, and could certainly take a picture of the torn boot. Sidey
/ Leaking Gas Tank #5
I too have the leak, and yes the factory still says they have no tanks. I found that the metal shield bolts have poor alignment. This caused pressure on the molded in nut in the tank, therefore the tank leaked around the nut. I removed the shield, bought a 2" rubber washer, a 1 and 1/2 " metal washer, with the fuel tank empty I placed JB weld then the rubber washer then the metal washer and used the bolt to hold in place. This is a temp fix until I get the tank. It is working, I really have to be carefull the metal shield is off.
Thanks.
/ Leaking Gas Tank #6
Thanks for the update Blueriver
I have a 5740 is there anything I should check to be proactive and prevent the issue from occuring?
/ Leaking Gas Tank #7
Not that I am aware of, when I took the shield off that is when I noticed the pressure against the bolt and the leak was revealed.
Thanks.
/ Leaking Gas Tank #8
Thanks.
Hi Blueriver, I have the 5740C tractor. It has been 3 1/2 years now. I wish I would have read your reply a little closer when you posted. I too have the leak at the front corner of the fuel tank. I noticed when removing the guard plate, that the holes are not spaced the same. I have had to grind the holes out to re-install. If I would have done this up front years ago, I would not have the problem now. I noticed a small crack at the molded in nut. Now for the question, does anyone know of a good fix for this? I tried putting some gasket sealant around the nut and it worked for a week or so. I think the fuel just disolved it or something. It only oozes and drips slowly. I would try a weld repair if someone can tell me the proper filler to use. I think if I just fill the hole where the nut is molded I would stop the leak. I can then make a bracket to hold the guard in place. Just for the record, what is the cost of a new tank? Just bothers me that the dealers did not get on top of this and do some p/m to avoid this mess later for their customers. I bought my tractor 3 years ago in May of 2005. Otherwise, I love this tractor. Please help me Maka or someone.....
Thanks,
Jim T.
/ Leaking Gas Tank #9
Cheers.
Glenn.
Walmart sells a cupholder in their Sporting good section for boats. It has a cupholder and small parts basket. The unit is held in place by a couple of small suction cups. I put mine on top of the fender in my cab and used the suction cups against the window to keep it from sliding around. This gives me a nice handy place for small items and is a great cupholder. I dont remember the price for sure but I think it was around 10.00
/ Leaking Gas Tank #10
JimmyBean,,
I'm running for public office here in this November's election, so I've been very busy, as you can imagine. I've been into my barn only and mostly to get sacks of feed daily and new political signs to go put up. My 5740C is parked in the back of the barn, out of the way of fed and signs.
I bought my 5740C in Feb 2005, and last used it approx 4 weeks ago due only to politicking. Before parking it in the barn, I filled up the diesel tank to the top. About 3 days ago, I went out and had to get something in the back half of the barn, so I turned on the set of lights for that area. As I walked along side the tractor, I noticed a large diesel spot on the cement floor, under the tractor, with a spot about 4 feet long and a foot and a half wide. I could smell diesel, but haven't had time to get into it yet. I think now I know what's going on.
I too am interested in any type of weld that might help seal the tank. I will try to get into this on Sunday when I have time. Any replies would help regarding a weld material that might help. This ISN'T right, IF Montana knew they had this problem, and I'm out of warranty anyway, by a long shot!
/ Leaking Gas Tank #11
Hey Unclebuck257,
I totally agree with the comment about not fair if Montana knew about this problem. Why didn't they contact their dealers nationwide? I wonder if we can band together and get some compensation. Like an auto, there should be a recall on the tank. What about the liability issue here? I now have a spill on my dirt floor barn that DER would be real happy about!!!!! And that is not to mention the fire hazzard. I sold a 40 year old Oliver that never leaked a drop. I have a 64 year old Allis that does not leak. What does that say for the old boys? They put steel tanks on those models though. I think anyone with this leaking problem should contact Montana and ask for a free repair regardless of the age of the tractor. Mine is the 5740C purchased new is May of 2005. Neat how it just ran out of warranty a few months back. Let's hear from the rank and file here and see how many people have the same problem. Just venting a little I guess, but very unhappy about a $30,000 purchase right now!
Jim T.
/ Leaking Gas Tank #12
That's right , it does not matter if it is out of warranty or not . It should be a recall as it is not only an inviromental issue but also a fire hazard and if by chance the Diesel run accross the barn floor and got into some Nitrate fertilizer (a weaker form of Nitropril) it would go off like a bomb . You people have the combined power of this forum to put pressure on the makers , i suggest you use it .
/ Leaking Gas Tank #13
I know of a product that will for sure repair that leak.
(and will do so permanantly)
It is called PRC and is used in the aviation industry to seal fuel tanks in the aircraft wings.
They also use it to bond plexiglass windows to aluminum structure.
It is a 2 part process, very adhesive and remains flexible when cured. (don't get any on your hands)
A search under 'aircraft parts & supplies' should locate this.
/ Leaking Gas Tank #14
To be fair to Montana. We have heard of a few people that have had that problem out of how many tractors. As far as my tractor goes I have not noticed a leak yet. I dont have a lot of hours on mine so as I use it more it might start leaking but I am pretty rough on it and have not had any problem yet. I imagine compared to the amount of ford, chevrolet, dodge, toyota, etc cars that were sold where the manufacturer knew about the problem and did not fix it. If there is a tank problem and Montana knows about it they are small potatoes compared to the way the auto industry treats customers. Can you say chevrolet 350 Cubic Inch diesel engine.
/ Leaking Gas Tank #16
Guys, a year later and I have not replaced my tank, the new one sets in the shed for future use. My JB weld repair has held!! I did however modify the guard and replaced it.
I am thinking the repair will out last the new tank!! Sorry I got the only available replacement tan!!
/ Leaking Gas Tank #17
blueriver,
Just for yucks, what did that replacement tank cost you? I'm going to go back and check your repair post in detail and compare that to the recent post from PILOON and that aircraft patch material he mentioned, after I check on that material.
I got to thinking that with the price of diesel as high as it was, I rarely put my tractor up with a tank filled, as I did this last time. Usually, it would be 1/2 to 3/4 filled, but never completely full. I'm thinking that since this was the first time I've ever seen any fuel tank leak, it had to do with the full tank due to fuel weight, volume, or something like that.
This politicking is taking most all my time right now, but I'm going to call my buddy who is a mechanical whizz and get some help from him. Hopefully, I can gt mine fixed without a new tank and get it done soon.
As far as a "class action" against Montana due to these fuel tanks, that'll take way too much time that I don't have right now.
/ Leaking Gas Tank #18
The tank did not cost me, my dealer handled that. The repairs were minimal, the cost of the flat washer, rubber washer and JB Weld. I top my tank every time I park the tractor.
I had a real problem starting the tractor after the tank repair ... I just couldn't get the air out of the system, so I thought! Anyway ... I put in 5 gallons of fuel and tried for hours to bleed the line. I called my dealer, he said it would not prime unless the tank was full. Filled it and it fired right up. BTW, my dealer sent me a check, from his business for my time and any cost I had consumed.
Personally, after my inital so called problems, and once I adjusted my attitude, then I became more diplomatic and WOW my dealer and Montana have been just super great. My next tractor will be another Montana.
/ Leaking Gas Tank #19
Well, yesterday afternoon I drove my tractyor down to my buddy's ranch and into his "shop". After what I learned from this thread, we immediately checked the areas with the screws holding the protective plate under the fuel tank. Sure enough, it was one of those screws that had caused the molded screw area in the fuel tank to crack and that's where the leak was.
We had already sifoned out the diesel that was left in the tank prior to starting, so we removed the protective plate and the five screws that held it on. After cleaning the area with a clean rag, we could clearly see a crack in the molded plastic about 1/4-3/8 inches long, coming out from the molded screw hole.
My buddy first took a hot soldering gun and seared over the crack in the plastic. We had already decided that we were not going to put that particular screw back in but rather use the other 4 screws alone to hold that protective plate on. After searing the crack, he then took a special apoxy and filled the screw hole, along with bringing the apoxy out from the screw hole to the area where the crack was and covering that area with apoxy too. After allowing it to dry for a short amount of time, we then replaced the protective plate and filled the fuel tank back up with 5 gallons of diesel. NO LEAKS!!
I should also add that after we repaired the leak and went to reinstall the protective plate, we had to enlarge two of the screw holes on the end that were already enlarged holes from the factory, because they wouldn't match up correctly. Apparently the tank itself had stretched, thus causing the strain that caused the crack.
As my buddy and I said, and we've all agreed in here, if this is a flaw in the tanks and Montana knows it, MONTANA should replace these tanks, warranty or not!!
Oh well, mine is fixed and now all I have to worry about is cleaning up all that diesel that leaked onto my concrete barn floor.
/ Leaking Gas Tank #20
Thats good news. Glad to hear the leak is fixed!! Do you think they really will do a recall? As I stated earlier ... other than a few small items, I am really impressed with my Montana, for instance,,, I really use this investment, probably more so than others, examples ... I have a front spear and a rear spear for hay, I cut hay with a John Deere disc mower, rake with a New Holland 256, bale with a Case IH 8430, plow with a JD 3-14 bottom plow, pull a case IH 10' tandem disk, use a 6' box blade, seed with a 12' JD grain drill, plant with a JD 2 row, cultivate with a JD 2 Row, use My FEL for everything from manure piles to moving dirt ... This machine is a do all for me. The versatile uses are great, it does not matter weather I am simply admiring the looks or the task that I have accomplished, simply put it is truly more than I expected ... BTW I read the same MFG makes Kubota ... I can find filters and now they tell me the Kubota Dealer can cross reference anything I need!! Post script ... There is a dealer in Hattisburg Mississippi, to him it makes no difference where you made your purchase he will help you in any sitiuation ... great guy!!! If you would like I would be more than glad to give out is contact info ..... God Bless Montana and Montana Owners, everyone else simply does not know what they are missing!!!!!!!!!!!!!!!!!!!!!!!!!
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
2006 Ford Crown Victoria Sedan (A61574)
2006 Ford Crown...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
