Iseki TS1910_3 3.00 star(s) (1)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Iseki TS1910_3.
Under 25 HP Tractors
About the Iseki TS1910_3
Iseki TS1910_3 Discussions (27)
Here are the most recent TS1910_3 topics from our community.
  1. A
    Iseki TS1910 glow plugs
    Hi, looking to replace the glow plugs on my TS1910, currently they have a set of JKC 10.5v 6k glow plugs that are 88mm long with a 24mm long glow element. I can't find any info on JKC plugs but...
  2. J
    Iseki TS1910 oil coming out of breather cap
    This is an Iseki TS1910, G192. I got it and it had sat for 3 years. I got it running, by a lot of cracking open fuel lines and cranking, pressurizing the fuel tank, and a little starter fluid (I...
  3. tucker2
    Oil & Fuel What type of trans/hyd fluid for Iseki TS1910
    Looking at the dipstick the oil looks like a heavy transmission type, not the thin hydraulic fluid type most newer tractors use. Does anyone know the correct fluid for the Trans/hyd. Also...
  4. M
    iseki ts1910
    hi i am new to this forum. i am owner of iseki ts 1910 and i am in a service period and i am looking for the service manual to download or some boby send with email. free or with money. sorry for...
  5. K
    Bolens G192 (Iseki TS1910) Auxiliary speed Change Lever Stuck?
    I have a Bolens G192 that sat for approximately 10 years in a barn. It only has 412 hours! With just a little TLC it is running great and I have managed to un-stick the clutch with a putty knife...
  6. D
    Steering Gear for Iseki TS1910
    Does anyone know where to find a replacement steering gear box for a Bolens G-194 or Iseki TS1910LF? Prefer a used one... or a rebuild kit/parts. Is there any Steering Box that will work on the...
  7. B
    Looking for Iseki TS1910 manuals
    Hi Guys and Gals, I just bought an Iseki TS 1910 tractor and am looking for the owners/service manual. I emailed member lens12 but haven't gotten any response. Hope he is ok. I also have a...
  8. D
    Iseki ts1910 seat
    Received a new seat for my tractor. Brackets do not match current seat. All searches bring up the same seat. Is there a different seat available for this late 70s tractor?
  9. P
    Iseki TS1910 / Bolens G192 Wheels - What other Brand Models Fit?
    I have an early Iseki TS1910, serial number 000020?. I have ag tires, I would like to get some wheels and tires better suited to lawn care, and keep the current tires and wheels. I have...
  10. H
    Newbie needs some info on a Iseki TS1910 4x4
    Hey every one. I'm new to the forum. I'm From SC. I currently don't own a tractor, but hopefully that will soon change. Been looking on the forum for info. Nice and a lot of info on here, but...
  11. R
    radiator hose - Iseki TS1910 Bolens G192
    For those looking for an upper radiator hose for a Bolens/iseki TS1910, i found a cheap alternative. i found the 2AA1 motor was put in Bobcats. That part is #A-6576028 and $6.00. Ordered through...
  12. J
    Buying Advice Bolens G192/ Iseki TS1910 front grill
    I need a front grill for a Bolens G192. If you have one or know where I can get one please let me know. Thanks!
  13. G
    Questions about Iseki TS1910 transmission
    I recently bought an Iseki TS1910 tractor. I have gone over it, repainted it, and replaced the idiot lights on the dash with gauges. The brakes are on a shaft in front of the rear axle. The seals...
  14. C
    iseki TS1910
    Where to find a new fuel filter and housing(cup)? And how much?
  15. Bull88
    Bolens G192/Iseki TS1910 Bucket Source?
    On this website, I have seen pics of TS1910s with FELs. I have a Bolens G192, which I understand is the same as a 1910. Is there a source for the bucket assemblies?
  16. K
    Iseki TS1910 Dash Lights
    What do the three lights on the right side of the dash represent? I have one coming on and want to make sure that my machine is tip top.:)
  17. RobertBrown
    Bolens G192/Iseki ts1910
    Anybody want to buy my tractor? It runs and works fine.
  18. R
    Brakes on Bolens G192/Iseki TS1910
    i didn't realize how bad i needed brakes until i hooked up a rotary cutter. Scary! Does anyone have any sources/prices for my tractor? baby needs new shoes. thanks, russ.
  19. R
    Iseki TS1910 FEL pics
    I have pretty much finished the FEL and repainted my tractor ..
  20. P
    Iseki TS1910 fuel filter
    I just took my TS1910 out of service to perform numerous service items. One was a change of the fuel filter and cleaning of the bowl. Everything went well except for the fuel filter gasket. I...
[ad placeholder]
User Reviews (1)
Read what TractorByNet members think about the Iseki TS1910_3 Subcompact Tractor
5
0 %
4
0 %
3
100 %
2
0 %
1
0 %
3.00 star(s)
scooterseats
TS1910_3 Iseki
Iseki TS1910
Model Year: 1978
I bought this tractor primarily for the loader feature. It also came with a Shredder and a Box Blade. When I was looking, the small tractor/loader market was fairly dry so when I found this I jumped on it despite of it needing lots of TLC. I really do not believe the previous owner even owned a grease gun. This poor tractor was starved for repairs and maintenance. There was no battery, no brakes and the seat was rusted almost completely away. The tractor has a single stage clutch so running a shredder without an over running clutch is probably the reason the brakes were gone. My first purchases were a battery, new seat and an over running clutch. After this I repaired the brakes and greased every joint and bushing on the tractor. I replaced a few bearings ( front wheel and brake shaft). Since the initial refurbing, I have had virtually no problems. Is it perfect, by no means it is but, it starts every time, does all tasks asked and is a very handy tool to have around. To summarize, I really like this tractor.
Pros: Low initial investment price. Even though I knew I had some maintenance issues, I knew I could do them myself.
Cons: Little things like gear noise (could have always had these), hard to mount, single stage clutch.
[ad placeholder]
Iseki TS1910_3 Owner Pages
View owner pages to see photos, customization and comments about member-owner Iseki TS1910_3s
Iseki TS1910_3 Community Rankings
#282 user rating of 731 Under 25 HP Tractors items
#594 Viewed of 731 Under 25 HP Tractors items
#82 discussed of 731 Under 25 HP Tractors items
#2206 user rating of 19625 items overall
#6243 Viewed of 19625 items overall
#480 discussed of 19625 items overall
