John Deere 670_2 5.00 star(s) (2)
Information, reviews, photos, discussion topics, owner pages, and specifications about the John Deere 670_2.
Under 25 HP Tractors
About the John Deere 670_2
John Deere 670_2 Discussions (55)
Here are the most recent 670_2 topics from our community.
  1. J
    John Deere 670 mid mower deck removal help.
    Hello I purchased a JD 670 with a mid mower. I’m trying to remove the mower deck got to disconnecting PTO and can not figure out how to. Can someone please advise or show pictures of the...
  2. F
    JD 670, switching from mowing to Ag setup
    Hey All, I am looking at switching my 2WD 670 from the previous owners lawn mower setup to something more like a row-cropper. It has some rather worn out and very wide (31x15.5-15) turf tires on...
  3. E
    Deere 670 Hydraulics
    Hello good TBN people. Firstly, I apologize if there's already a thread on this. I seem to be having a difficult time using the search function in a meaningful way, but I did poke around a bit...
  4. J
    Land Planer Grader & John Deere 670 4WD
    I've been looking for a not-too-expensive used tractor to maintain my 800' gravel driveway. The driveway is pretty much level all the way with a couple of spots with gentle grades. I've found a...
  5. B
    JD670 (770) Rockshaft cover and the Lift Lever Linkage problem to solve
    Does anyone have experiences removing the rockshaft cover on a 670? My 3 point only moves a small amount and I am thinking the lever control linkages may be bent. While digging a post hole is only...
  6. J
    John Deere 670 Leaking Oil Front
    So I purchased a JD 670 on Sunday morning, its a pretty clean 1400 hour machine with a few dings on it but hardly any rust and seems to run well. It has a bush hog 1846QT loader and turf tires...
  7. J
    Switching parts from one JD 670 to another
    HI all. A little over a ago we purchased a small farm that came with a JD 670. It also came with a mid mount mowing deck and a rear mount snowblower. Both have been great! What we really need...
  8. D
    John Deere 670 Mid-Mount Mower Removal
    Hello, I picked up a 1996 John Deere 670 (850 hours, loader and mid-mount mower). What's the procedure for removing the mid-mount mower for service? I picked up a service and operators manual...
  9. B
    3-Point Hitch Deere 670 3PH issue
    I've got an early 90s 670 that has been sitting in a barn for a couple years. Everything was working fine when it was parked. It runs good now, but after sitting the 3ph has zero movement. The...
  10. D
    JD 670 temperature gauge
    Hey everyone, first post on this site. I have a JD 670 that the temperature gauge quit working on, I switched the fuel gauge with the temp gauge and it worked (needle just goes backwards) so I...
  11. T
    JD 670 Mid PTO won't engage
    Is the JD 670 totally mechanical? The mid PTO has been a little rough, grinding when being engaged. Now it won't engage at all, it just grinds. Any thoughts?
  12. K
    JD 670 attachments
    hello all, i recently purchased a 1996 JD670 FEL tractor. i am looking to get a idea of some attachements. i would like to get a set of pallet forks for it. Also looking for a backhoe attachment...
  13. K
    1996 JD 670 wiring help needed
    Hello all i recently purchased a 1996 JD 670 tractor with loader that was sitting for approx 1 1/2 years. i went threw it and got her running. I did not have any fuel at first when i cracked...
  14. L
    Mowing JD 670 dead. Wheres the fusible link?
    No power. Battery is good. We just replaced battery terminal clamps. but no power! Where is the fusible link?
  15. G
    87' JD 670 loader hydraulic hose connection question
    I have a 1987 John Deere 670 with a 60 front loader. I just inherited this tractor and I'm hooking up the 60 loader, which has been done except for the hydraulic hose connections. On the tractor...
  16. C
    John Deere 670 tractor overhaul kit help
    Hi, Im brand new here. Ive read several post on this site before and seems like a great place to get some information. I have agreed to buy a John Deere 670 sub compact tractor from a friend for...
  17. M
    john deere 670 with 60 loader
    need to replace hydraulic hoses and repair leaking hydraulic cylinders
  18. B
    Brake Parts John Deere 670 Compact
    I'm looking for the best source for brakes or a brake kit for a John Deere 670 compact tractor. I see parts advertised on ebay but I'm not sure if they are good quality? Any recommendations would...
  19. R
    JD 670 steering wheel removal
    I have a John Deere 670 Compact Utility Tractor that needs the headlight switch replaced (corroded and frozen up). First step to getting behind the instrument panel is to remove the steering...
  20. R
    Loader JD 670 with 60 loader cylinder repair.
    As mentioned in title, I have a JD 670 with Model 60 loader with one of the bucket tilt hydraulic cylinders leaking like a sieve. Does anyone have info or literature on how to rebuild the...
[ad placeholder]
User Reviews (2)
Read what TractorByNet members think about the John Deere 670_2 Subcompact Tractor
5
100 %
4
0 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
Rrolson
670_2 John Deere
Review of Older Compact JD 670 Tractor
Model Year: 1989
I like the tractor fine. I have had it many years and have not had to do any repairs to speak of. I use it for mowing and tilling and moving things around with the front end loader. Now I am going to fabricate a small back hoe implement, the design of which I acquired from PF engineering. I am interested in any other users experience with these small back hoes.
Pros: Lightweight so it can be trailered; 4 WD; reliable diesel engine; 3 pt hitch.
Cons: No power steering; not big enough for serious plowing.
5.00 star(s)
JohnDeereHere
670_2 John Deere
1997 John Deere 670 MFWD
Model Year: 1997
Tractor has plenty of power for it's size.Very easy to operate.Very easy on fuel. I love it!
Pros: Power, ease of use, fuel economy.
Cons: Parts for the tractor usually have to be ordered.
Photo Uploads:
[ad placeholder]
John Deere 670_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner John Deere 670_2s
John Deere 670_2 Community Rankings
#1 user rating of 731 Under 25 HP Tractors items
#159 Viewed of 731 Under 25 HP Tractors items
#46 discussed of 731 Under 25 HP Tractors items
#1 user rating of 19625 items overall
#1231 Viewed of 19625 items overall
#269 discussed of 19625 items overall
