John Deere 6410_3 3.00 star(s) (1)
Information, reviews, photos, discussion topics, owner pages, and specifications about the John Deere 6410_3.
50-100 HP Tractors
About the John Deere 6410_3
John Deere 6410_3 Discussions (17)
Here are the most recent 6410_3 topics from our community.
  1. L
    john deere 6410 engine wiring issues
    Hi, I have the jd 6410 engine rebuild and the engine loom has some issues as the tractor does not start. Before it was starting OK, now the dash bord is lit up and when I tried to start the...
  2. J
    John Deere 6410 Hydraulic system overheating
    I'm having trouble with the hydraulic system overheating on a John Deere 6410 that was built in Germany. The whole transmission gets very hot to the touch, at times it has gotten so hot the...
  3. S
    John Deere 6410 hydraulics overheating
    Good evening, new to the site. JD 6410 hydraulics are overheating due to scv valve sticking, or so I think. I repaired the brake valve already at this point which fixed one problem. When I pull...
  4. S
    john deere 6410
    forward and reverse not working
  5. R
    How to Clear John Deere 6410 Error Codes
    I have a John Deere 6410. seems to choose on its own when the day is done and just won't move after cutting hay, bush hog, etc. Sometimes you can restart it, or let it rest for a few minutes...
  6. M
    JOHN DEERE 6410 WITH CAB
    I WAS BUSH HOGGING, LISTENING TO RADIO RUNNING WELL, GRASS WAS NOT TALL AT ALL, ALL OF A SUDDEN RADIO STOPPED, LOOKED DOWN ALL DASH GAUGES AND ALL HAD STOPPED, LOOKED BACK PTO HAD STOPPED, TRIED...
  7. M
    JOHN DEERE 6410 WITH CAB WONT START WITH KEY
    I WAS BUSH HOGGING, STOPPED TO GET SOME WATER TO DRINK, WHEN I GOT BACK IN IT WOULD NOT START WITH KEY, I REPLACED THE SWITCH, THEN THE SOLENOID, AND NOW HAVE CHANGED THE NEUTRAL START SWITCH...
  8. S
    JD6410 remains in FWD
    Guys I understand the MFWD solenoid needs permanent power to keep it out of FWD. I have tested the solenoid,it generates magnetic field. I have removed the valve assembly, that also works fine...
  9. I
    1999 John Deere 6410 with 640 loader
    yes i have a 1999 john deere 6410 with 640 loader it has a powrquad transmission. the tractor at first when operating it would drive and shift then start beeping when traveling. went out and...
  10. S
    JD6410 difflock wiring
    I can see the diff lock switch is powered from ignition. Also, relay K110 terminal 30 is not powered from a fuse. Can you guys help me complete the drawing?
  11. S
    JD6410 Head light wiring
    I have the European edition. Can you guys review my 2 drawings. I need help with diode V104 and fuses F110 and F111. How about a schematic? that will be fantastic!
  12. S
    JD6410 wiring for Rotary light switch
    Guys Can you help with basic wiring in picture. Albert
  13. W
    John Deere 6410 won't move
    2000 6410 powrquad 24 speed. Round baled with it 2 weeks ago. Everything was fine. Last week I went to use it and it will not move. Low trans pressure ligh and stop light flash when engine is...
  14. W
    John Deere 6410 tractor won't start
    I have a 2001 6410 tractor that won't start all of a sudden. It was fine the day before. My first guess was the starter went bad, but after checking to see if the solenoid was getting power...
  15. 9
    john deere 6410 temp guage
    My 6410 is running hot according to the temp gauge. But when I check the temp with a temp gun, it shows its running around 190 Any ideas????
  16. K
    John deere 6410 misfire
    Hello to all I'm new here, hope I can help people and get some help for myself. I've got a 2000 JD 6410 it acts like its got a misfire but when I block the lines all 4 injectors are firing the...
  17. B
    JD6410 2004year lift arms wont raise
    Ok sorry only way i knew how to post this wher it would be seen! Stoped working all at once! all remotes work fine! thanks !!!
[ad placeholder]
User Reviews (1)
Read what TractorByNet members think about the John Deere 6410_3 Subcompact Tractor
5
0 %
4
0 %
3
100 %
2
0 %
1
0 %
3.00 star(s)
hounddog1
6410_3 John Deere
John Deere 6410
Model Year: 2001
It was great to see the quick response from other board users. This particular tractor has been designed by non-tractor users (i.e. it runs well, etc.), but is a nightmare to fix on farm. As farmers, we cannot afford to bring it in to the dealer, especially since we are so far away, and it is too costly.
Pros: Easy handling.
Cons: Horrible to fix.
[ad placeholder]
John Deere 6410_3 Owner Pages
View owner pages to see photos, customization and comments about member-owner John Deere 6410_3s
John Deere 6410_3 Community Rankings
#344 user rating of 1508 50-100 HP Tractors items
#340 Viewed of 1508 50-100 HP Tractors items
#83 discussed of 1508 50-100 HP Tractors items
#2206 user rating of 19625 items overall
#2193 Viewed of 19625 items overall
#618 discussed of 19625 items overall
