Ztrack 60 inch - speed override
   / Ztrack 60 inch - speed override #1
saxon11
Minnesota
TYM T474
Hi - i have purchased the 60 inch Ztrack earlier this year. I'm looking to adjust it for faster while i mow. Is there an adjustment on the engine somewhere to do this? Also, when I push both handles all the way, the mower doesn't quite go straight (veers to the right a little bit). Assuming there is an adjustment bolt for that? thank you
   / Ztrack 60 inch - speed override #2
What rpm is the engine running now? If you don't know, I would say no to the first question. Tampering with the governor will most likely void your warranty and shorten the life of the engine.
The answer to the second question is yes but depends on the type of transmissions and linkage used in your model. That should be covered in your owner's manual. If it's the control arm linkage, that should be accessible from the top. But if it's a transmission neutral adjustment, it will most likely require you to raise/jack-up the mower to access the adjustments. (And be able to run it in the raised position.)
The best-case scenario would be for you to seek service from a dealer.
44in Tooth Excavator Bucket (A51691)
44in Tooth...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2013 Club Car Carryall 252 Electric Utility Cart (A51691)
2013 Club Car...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
