Ztrack 60 inch - speed override
   / Ztrack 60 inch - speed override #1
saxon11
Minnesota
TYM T474
Hi - i have purchased the 60 inch Ztrack earlier this year. I'm looking to adjust it for faster while i mow. Is there an adjustment on the engine somewhere to do this? Also, when I push both handles all the way, the mower doesn't quite go straight (veers to the right a little bit). Assuming there is an adjustment bolt for that? thank you
   / Ztrack 60 inch - speed override #2
What rpm is the engine running now? If you don't know, I would say no to the first question. Tampering with the governor will most likely void your warranty and shorten the life of the engine.
The answer to the second question is yes but depends on the type of transmissions and linkage used in your model. That should be covered in your owner's manual. If it's the control arm linkage, that should be accessible from the top. But if it's a transmission neutral adjustment, it will most likely require you to raise/jack-up the mower to access the adjustments. (And be able to run it in the raised position.)
The best-case scenario would be for you to seek service from a dealer.
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
FRONTIER AH11G LOT NUMBER 112 (A53084)
FRONTIER AH11G LOT...
