ZTR Maintenance
/ ZTR Maintenance #11
I've not had good luck with the chinese made carbs either. On an old B&S engine 7hp. And on several weekwackers and chainsaws no luck.
I'd try the "Mechanic in a bottle" from Lowes or Home Depot. They are nearby to everyone and they stock that stuff. Surging is due to dirt in the carb usually. New plugs won't hurt it but that's not your problem.
/ ZTR Maintenance #12
I had poor luck with those cheap carbs, I noticed a loss of power with them, put one on my Echo trimmer and it started and ran but at a loss of about 1/3 the power and rpm. Ended up buying an Echo carb and it runs like it did when I bought it new. Cheap carb was $25, Echo carb was $65, so now I’m out $90.
/ ZTR Maintenance #13
I've had no problems with the cheap Chinese carbs. Worked perfectly in my weed whacker and push mower. That said, I am slowly converting all my gas lawn tools to cordless. The batteries are getting better and better and the power on the newer tools is equal to gas.
I second Seafoam. I had another push mower that surged and Seafoam solved the problem.
/ ZTR Maintenance
This is to follow up on the post and let y'all know what the fix was.
I got a bottle of seafoam, put it in the tank and started up the ZTR. It surged which I expected it to do, then went out and mowed the yard. 2 hours later I came back to put it away and it was purring just like new. The seafoam worked just like y'all said it would. I've not done anything with the plugs, I'll wait until they come up in the maintenance schedule.
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
2019 Felling Trailers 9 Ton 18ft T/A Flatbed Equipment Trailer (A59230)
2019 Felling...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2025 72in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A59228)
2025 72in...
