ZRT 50 won't start (after running well, then sputtering, and died ...with oil light on)
   / ZRT 50 won't start (after running well, then sputtering, and died ...with oil light on)
Correct. Should still crank but not start. Just wondering if the pto was engaged at the time it died. And has been overlooked while trying to restart.
PTO was not engaged; (good thought though). And with that, I did pull the PTO knob - heard that solenoid snap/click - so I know it's functioning. But still ZERO sound/activity when I try to start. No bound up starter or anything. I gotta try turning the crank/pulley underneath and confirm if engine is seized, but, having worked on many machines before, I don't think that's the issue. I'd hear the starter Try and move the flywheel but that aint happening. Feels like a switch gave up the ghost, just gotta figure which one. And strange that it was running just fine and then peter'ed out and quit and now, bupkiss.
   / ZRT 50 won't start (after running well, then sputtering, and died ...with oil light on) #12
Even with a seized engine you should still hear the starter solenoid try to engage the starter. So that leaves the brake switch and the neutral switches on the levers. Or could also be a relay issue associated with those components. and unfortunately MTD is not well known for having wiring diagrams for their mowers.
Thank you, RandyT. Yea, my gut sank a little when I noticed the "MTD" in the model number tag.... But I can ohm out the switches, one by one, until I find the culprit - or move onto other suspects like bad ground. Again, (last time I'll say it), weird that it was running fine and then died. But, if a switch crapped out ...it crapped out.
   / ZRT 50 won't start (after running well, then sputtering, and died ...with oil light on) #14
Any signs of mice chewing on wires?
   / ZRT 50 won't start (after running well, then sputtering, and died ...with oil light on) #15
@jpilk99 The MTD is nothing new with Cub Cadet since they have owned them since 1981, Which is now owned by Stanley Black and Decker
Ahhh. I just know when I look at machines that people get at Lowes or Home Depot, that are painted green & yellow and say John Deere, or orange and gray and say Husqvarna, but at the end of the day ...theyre MTD...
   / ZRT 50 won't start (after running well, then sputtering, and died ...with oil light on) #18
Any chance it’s the battery? Did you load test the battery?
   / ZRT 50 won't start (after running well, then sputtering, and died ...with oil light on) #19
Having some trouble looking up a Cub Cadet ZRT model.
Are you sure that this is not a RZT ?
Richard
   / ZRT 50 won't start (after running well, then sputtering, and died ...with oil light on) #20
Richard - its the RZT 50 with the Kohler KH720 Vertical Twin Engine per the previous post. Per the tag the engine was built in 2012.
It sputtered and died which to me points to fuel..
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
2003 Big Tex 10PI...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A55853)
1990 21ft Center...
