ZL 20 Loader relief pressure
   / ZL 20 Loader relief pressure #1
Amez
BC,Canada
Jinma 284
Does anyone know what the relief pressure should be for a Jinma 284 loader ? Mine is around 2000-2500 psi with the replacement loader valve from Ranch Hand Supply. (That was not with the hydraulic oil fully at operating temperature.)
   / ZL 20 Loader relief pressure #2
For the ones that have been brought here for service .......... I have seen the factory ZL20 & ZL30 loader valves relieving anywhere from 800 - 2600 lb. Nothing consentant.
Your window of 2000 - 2500 seems a little wide to me ?
I like to see 2200 - 2400 .... not over 2500.
Ronald
Ranch Hand Supply
   / ZL 20 Loader relief pressure #3
I googled around and found this -
JINMA OEM FRONT END LOADER ZL-20
FOR 20-28HP TRACTORS
Attachment Model : Jinma Front End Loader - 20
Model # : ZL-20
Tractor Sizes : 20 - 28HP
Bucket Size : 50" (inches)
Bucket Capacity : 7.1 feet cubed
Hydraulic Cylinders : Double Acting
Hydraulic Pressure : 2400 psi.
Control Valve : 2 Spool Valve
Bucket Cylinder : 2" x 23" (inches)
Lift Cylinder : 2" x 23" (inches)
Lift Capacity At Full Height : 1500 lbs
Breakout Force : 1835 lbs
Dimensions : 89" x 43" x 32" (inches)
Structure Weight : 600 lbs
   / ZL 20 Loader relief pressure #4
I'm not sure where that data came from but it's incorrect,the lift capacity on the ZL-20 is around 800lbs, I have the specs at the shop from the ZL-20 manual and will get them,My Ansung Korean loaders have a lift capacity of 1550 lbs and the cylinders and steel are twice the size of the ZL-20
Tommy
Affordable Tractor Sales
   / ZL 20 Loader relief pressure #5
I wouldn't argue with Tommy.
Dang internet, I just googled and found it at a site, did a cut and paste.
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A51039)
Adams Load Out...
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
