ZL 20 Loader relief pressure
   / ZL 20 Loader relief pressure #1
Amez
BC,Canada
Jinma 284
Does anyone know what the relief pressure should be for a Jinma 284 loader ? Mine is around 2000-2500 psi with the replacement loader valve from Ranch Hand Supply. (That was not with the hydraulic oil fully at operating temperature.)
   / ZL 20 Loader relief pressure #2
For the ones that have been brought here for service .......... I have seen the factory ZL20 & ZL30 loader valves relieving anywhere from 800 - 2600 lb. Nothing consentant.
Your window of 2000 - 2500 seems a little wide to me ?
I like to see 2200 - 2400 .... not over 2500.
Ronald
Ranch Hand Supply
   / ZL 20 Loader relief pressure #3
I googled around and found this -
JINMA OEM FRONT END LOADER ZL-20
FOR 20-28HP TRACTORS
Attachment Model : Jinma Front End Loader - 20
Model # : ZL-20
Tractor Sizes : 20 - 28HP
Bucket Size : 50" (inches)
Bucket Capacity : 7.1 feet cubed
Hydraulic Cylinders : Double Acting
Hydraulic Pressure : 2400 psi.
Control Valve : 2 Spool Valve
Bucket Cylinder : 2" x 23" (inches)
Lift Cylinder : 2" x 23" (inches)
Lift Capacity At Full Height : 1500 lbs
Breakout Force : 1835 lbs
Dimensions : 89" x 43" x 32" (inches)
Structure Weight : 600 lbs
   / ZL 20 Loader relief pressure #4
I'm not sure where that data came from but it's incorrect,the lift capacity on the ZL-20 is around 800lbs, I have the specs at the shop from the ZL-20 manual and will get them,My Ansung Korean loaders have a lift capacity of 1550 lbs and the cylinders and steel are twice the size of the ZL-20
Tommy
Affordable Tractor Sales
   / ZL 20 Loader relief pressure #5
I wouldn't argue with Tommy.
Dang internet, I just googled and found it at a site, did a cut and paste.
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A52141)
2018 PETERBILT 579...
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
KJ 10' Galvalume Corrugated Steel Panals (A50121)
KJ 10' Galvalume...
