Zerostart 3200001 engine heater
   / Zerostart 3200001 engine heater #1
oldnslo
Super Member
Northern, IL
Branson 2400H, JD X540
Hi all,
Installed one of these lower radiator hose heaters in my BX and now it appears that every time the thermostat calls for heat there is a high inrush current that is tripping the circuit breaker.
The heater is 350 watts at 120 VAC and when oerating it draws between 3 & 4 amps per my amp clamp meter. I see the meter jump when the thermostat closes and about every 3rd or 4th cycle it trips the 20 amp breaker. I replaced the breaker thinking it maybe was weak from age and this made no difference.
I presume the heater is faulty and will have to be replaced.
Any other thought?
TIA
   / Zerostart 3200001 engine heater #2
I would tend to agree with your assessment.
   / Zerostart 3200001 engine heater #3
I also presume the heater is faulty and will have to be replaced.
Your heater or your wiring is exceeding the 20 amp ... by a LOT.. unless it is a GFCI breaker.
Some motor and Heater circuits will Not work well with GFCI breakers or outlets... KennyV
Non GFI Breaker or outlet.
1999 Pierce Quantum Fire Truck (A48081)
1999 Pierce...
PALLET OF ARMSTRONG TILE FLOORING (A50460)
PALLET OF...
2015 JCB 550-170 (A48837)
2015 JCB 550-170...
New/Unused 12ft x 7.4ft x 8.2ft Container (A48837)
New/Unused 12ft x...
NEW 2024 LOAD TRAIL 83IN X 20FT Tandem Axle Equipment Trailer (A50397)
NEW 2024 LOAD...
Pallet of (4) 10 Lug Misc Wheels (A48837)
Pallet of (4) 10...
