oldnslo
Super Member
Hi all,
Installed one of these lower radiator hose heaters in my BX and now it appears that every time the thermostat calls for heat there is a high inrush current that is tripping the circuit breaker.
The heater is 350 watts at 120 VAC and when oerating it draws between 3 & 4 amps per my amp clamp meter. I see the meter jump when the thermostat closes and about every 3rd or 4th cycle it trips the 20 amp breaker. I replaced the breaker thinking it maybe was weak from age and this made no difference.
I presume the heater is faulty and will have to be replaced.
Any other thought?
TIA
Any other thought?
TIA
