Zero turn fatality
/ Zero turn fatality #41
I almost flipped mine on top of me, so I installed AG tires and what a difference.
/ Zero turn fatality #42
I put bar tread tires and spacers on my backup diesel zero turn a few years ago. It sticks on slopes much better ... BUT, it has enough traction to pull the front end up and over if I'm going uphill (which I generally avoid).
It's also counterintuitive to me to pull back on the direction bars when the front end comes up. I am always thinking in my head what I'm gonna do if...
/ Zero turn fatality #43
Many years ago a professional mowing firm owner told me to mount my R1 tires backward. When I questioned that he said, you need more traction backing out of soft spots/mud than going forward, and they hold better on side slopes.
Time and experience has proven that true, at least on my Hustler ZTR.
/ Zero turn fatality #44
I am thinking that Dixie Chopper's used to be set up like that?
/ Zero turn fatality #45
More details in the article would be helpful.
My assumptions would either no roll bar up or no seat belt or both.
I have used one (Ferris) commercially since 2014. Have seen so many with ROPS folded down. Sometimes a pain under low tree branches. Small price to pay. The performance and sensitivity is scary for new, inexperienced operators.
/ Zero turn fatality #46
The rops gets folded down or removed because the owners previous Z turn didn't have one, and his first zip around the yard catches that branch and either bucks it up on its tail or in some cases have turned the mower over backwards. Have heard of a few that the branch broke and hit the operator in the back of the head causing serious injury.
/ Zero turn fatality #47
I got a concussion from that exact situation.
I was backing up in a powerful, heavy zero turn not knowing I was flexing a 4” pine branch backwards.
It skipped over the ROPS and clubbed me good on the back of my neck. Luckily I weigh enough that it didn’t knock me over onto the mowing deck.
I got a concussion.
/ Zero turn fatality #48
I got a concussion.
This is why mine is down... Unless I go cut a lot of branches
/ Zero turn fatality #49
/ Zero turn fatality #50
Mine are also down almost all of the time. I replaced the OEM pins with quick release pins so that when I'm mowing on a slope it's more convenient to raise and pin the rops.
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
Kubota M5-111 (A53317)
Broom Attachment (A59228)
Broom Attachment...
