Backhoe Zerks for KB 2485~ size?....
Status
Not open for further replies.
   / Zerks for KB 2485~ size?.... #51
Why were some of my posts removed? I have followed the rules.
   / Zerks for KB 2485~ size?.... #52
Sometimes we remove posts that are in reply to posts that need to be removed in order to keep the flow of the thread.
   / Zerks for KB 2485~ size?.... #53
Ahh, I see now. Thanks for the input.
Murphy,
The posts removal isn't about anything you posted.
   / Zerks for KB 2485~ size?.... #55
otay whatever..
   / Zerks for KB 2485~ size?.... #56
Yea, I noticed mine got removed also. But the recommendation on the drilling and tapping to 1/8" pipe is still a option. We sell Zerks for about 16 cents and they are steel not brass. CJ
   / Zerks for KB 2485~ size?.... #57
Re: Zerks for KB 2485~ size?.... My 2 cents
The grease doesn't get where it needs to be on most fittings using a needle tip. The grease needs to be in the middle of the joints to do any good.
A needle tip just lays the grease along the edges where its doing no good at all.
I beg forgiveness if I misinterpret, but that post (quoted) makes it sound like you think the needle tip is used around the edges of a joint (i.e. where the grease squeezes out). This is not the case. The needle tip is placed right in the center of the zerk, where it presses in the ball, and the grease goes in... into the same place as if a standard grease coupler is used.
I agree that if you try to grease the edges of a joint with that needle tip, the grease won't be where you want it... and it would take you 5 hours and 22 minutes to grease around the whole tractor!!! :laughing::laughing:
-Mitch
   / Zerks for KB 2485~ size?.... #58
Thank You Muhammad! :thumbsup:
Muhammad deleted posts from this thread at my request to either close the thread, eliminate it completely, or edit it, as was obviously needed.
Any other interpretations are merely misguided wishful thinking.
I would say, however, I would have preferred it being eliminated completely, but I left the decision to the admin.
   / Zerks for KB 2485~ size?.... #60
The thanks wasmt to ypu it was to Muhammad , others also complained not just you, but that's right your "special"
Status
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
