OK. The 4 PTO speeds on L2201 are:
1st....622rpm @2800engine rpm (540rpm@2430 on engine)
2nd...810 @2800
3rd...1160 @2800
4th... 1480 @2800
Sorry i meant to post this ages ago,but kept forgetting the info at work.
CSH, your pics look great. Beautiful country. Your tractor looks in really nice condition. The 5' rotary cutter is probably a bit big for it. We use 4 ft on these size tractors, but they drive 4 ft very comfortably. You can still stall them out in heavy going without trying too hard. If the growth is sparse it would have enough power to drive 5 ft.
Once we tried to lift over 520 kg on the rear of one of these, and it lifted fine but front started to lift off the ground. The hydraulics are quite good on these models.
Regarding counterweights, we make a profile cut from 2"steel plate and simply hang weight on the front bar. Each profile weighs 25kg, and 2-3 weights seem fine for most users. On steeper country we may go to 4 or more weights.Probably 60-80 kg would be OK on your application.2wd always needs more weight than 4wd.
Having said that, the last L1501 we added 4 weight too(customer has a very heavy post driver and should have bought a larger tractor, but his funds were limited), bent the front bar. We then cut the bent parts off and rewelded the bar with heavier material, and a lenghtwise stiffener which worked really well. Helps is you have a range of metalworking equipment for this.
As i understand it ,the 4th PTO gear is used for very fine rotary tilling, at creeper speeds, to get a superfine till. This would only work on well worked soil.But the high PTO speeds could also be used for driving generators or pumps or other belt drives where required.
Hope this helps.
BillK
Diesel Traders
