Zen-Noh B7000 lube question
/ Zen-Noh B7000 lube question #1
ErnieInTucson
Tucson Arizona
Zen-Noh (Kubota) B7000. Massey Ferguson MF35
The housing for the front driveshaft universal joint has a screw in plug on the bottom of the housing and another screw in plug on the side of the housing, both with a 10 MM head. Looking at the plugs I would assume that the side plug is for adding lubricant and the bottom plug is for draining lubricant. But no lubricant drains out when the plugs are removed and I can find no reference saying to put lubricant in this housing. The documents I've checked are
Operations Manual for Kubota B6100/B7100
Parts List for Kubota B7100
I&T Shop Manual for B5100/B6100/B7100
Should I put 80W gear lube in the housing for the front universal joint?
/ Zen-Noh B7000 lube question #2
I have a b7000 and i know what your talking about. I used 80-90 gear lube in that u-joint housing. And also in the front axle and the outer drives on the front axle.
40' CONTAINER (A52706)
2021 VERMEER S925TX STAND ON SKIDSTEER (A60429)
2021 VERMEER...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A61307)
FRESHLY...
JLG E300AJP TELESCOPIC/SCISSORING BOOM LIFT (A60429)
JLG E300AJP...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
