ZD326 Rear tire options?
   / ZD326 Rear tire options? #1
Joe Kidd
ZD326
Has anyone explored options for more rear tire traction? Turf-savers are ok, but sometimes sure lack decent traction. I suppose the heavy weight of the machine doesn't help either. I remember seeing a shallow cup design some years ago on the Grasshopper machines that may afford more traction, but I'm sure the trade-off is possible more turf damage.
   / ZD326 Rear tire options? #2
I took the OTRs off and replaced them with Carlisle Turf Masters. Noticable difference in traction. The OTRs were a stiffer tire and if they caked with mud between the tread it wouldn't clean out. Just didn't seem to have enough flex to them. I thought of trying HDAPs but didn't know what they would do to the turf on a zero turn.
   / ZD326 Rear tire options? #3
Make sure that you stay with a tire that has the same outer diameter so the deck will still run level.
   / ZD326 Rear tire options? #4
It is possible to tear turf with bar type tires. What I found on a ZG2354 was much better traction and actually less tearing. The mower stopped or turned instead of spinning tires. On damp grass it actually tore less. Performance on a grade was much better also.
   / ZD326 Rear tire options? #5
My dealer ordered a set of rear bar tires and rims (whole goods) for a bx2660, same size tires. Now I can switch rears between our dry and wet seasons. The turf tires suck in real wet grassbut the bar tires keep the zd moving...
2017 Ford Fiesta Passenger Car (A51694)
2017 Ford Fiesta...
2012 FORD E-SERIES 11 PASSENGER VAN (A52472)
2012 FORD E-SERIES...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
2018 JLG 3246ES 32FT. Scissor Lift (A51691)
2018 JLG 3246ES...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52748)
2015 Ottawa Yard...
