ZD326 Rear tire options?
   / ZD326 Rear tire options? #1
Joe Kidd
ZD326
Has anyone explored options for more rear tire traction? Turf-savers are ok, but sometimes sure lack decent traction. I suppose the heavy weight of the machine doesn't help either. I remember seeing a shallow cup design some years ago on the Grasshopper machines that may afford more traction, but I'm sure the trade-off is possible more turf damage.
   / ZD326 Rear tire options? #2
I took the OTRs off and replaced them with Carlisle Turf Masters. Noticable difference in traction. The OTRs were a stiffer tire and if they caked with mud between the tread it wouldn't clean out. Just didn't seem to have enough flex to them. I thought of trying HDAPs but didn't know what they would do to the turf on a zero turn.
   / ZD326 Rear tire options? #3
Make sure that you stay with a tire that has the same outer diameter so the deck will still run level.
   / ZD326 Rear tire options? #4
It is possible to tear turf with bar type tires. What I found on a ZG2354 was much better traction and actually less tearing. The mower stopped or turned instead of spinning tires. On damp grass it actually tore less. Performance on a grade was much better also.
   / ZD326 Rear tire options? #5
My dealer ordered a set of rear bar tires and rims (whole goods) for a bx2660, same size tires. Now I can switch rears between our dry and wet seasons. The turf tires suck in real wet grassbut the bar tires keep the zd moving...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2008 UTILITY REEFER TRAILER (A51222)
2008 UTILITY...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
2022 Ram Bighorn 2500 4X4 (A51039)
2022 Ram Bighorn...
2018 John Deere 645FD Flex Draper Head (A50657)
2018 John Deere...
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
