ZD221 vs ZD321
   / ZD221 vs ZD321 #1
Av8r3400
Platinum Member
North Central Wisconsin
Kubota L3400DT
Would any one care to discuss the differences between these two units? Are there differences in them aside from the cosmetics and chassis size? Maybe some technical information would be nice.
I'm looking for a diesel zero turn with a 54-60" deck. Pretty much sold on Kubota...
   / ZD221 vs ZD321 #2
The one spec I can see different is the 321 can raise the front with a gear to access the blades. The 221 can't do that. I have a ZD326. It is a tank. I love it. An option I didn't know about for mine is a rear discharge. I would have went with it had I known about it.
   / ZD221 vs ZD321 #3
There is a big physical size difference and it would make a difference while trimming with the mower.
   / ZD221 vs ZD321 #4
Looks like the 200 series is a "lighter duty" version for residential use. I went with a ZD331 and didn't look back. On the Kubota site it looked like the 60" isn't available for the 221 only a 54", not much differance unless you have a large area to mow.
19008 (A48082)
19008 (A48082)
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
