ZD 1211 Tires Change Question
   / ZD 1211 Tires Change Question
Well I had the dealer order a pair of rims from the ZD 300 series that I believe will fit 26/12-12 tires, thus the standard for ZT's.
Was looking for recommendations with something like a Carlisle Trac Chief which appears similar to a R1 vs. the Carlisle HD Field Trax which appears "knobby".
I'm not wed to either of these, just what I found on the internet. Trying to give the ZD 1211 as much grip on hills as I can.
Thanks for your help!
   / ZD 1211 Tires Change Question #12
Tires are more plentiful & cheaper for the smaller rim size but you’ll have more sidewall give IF you mow rough ground or have stump holes Causing scalping IF you mow shorter.
   / ZD 1211 Tires Change Question #13
I should have known you would have Bota ZTs. I just bought a 1211.
2007 Boston Whaler Boat w/ Dual 200HP Mercury OptiMax (A51694)
2007 Boston Whaler...
2000 Mack CH613 Day Cab Winch Truck (A53117)
2000 Mack CH613...
2025 K4525G UNUSED Double Garage Steel Barn (A53117)
2025 K4525G UNUSED...
Informational Lot - Financing (A53473)
Informational Lot...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
Trommel (A52377)
Trommel (A52377)
