ZD 1211 Tires Change Question
   / ZD 1211 Tires Change Question
Well I had the dealer order a pair of rims from the ZD 300 series that I believe will fit 26/12-12 tires, thus the standard for ZT's.
Was looking for recommendations with something like a Carlisle Trac Chief which appears similar to a R1 vs. the Carlisle HD Field Trax which appears "knobby".
I'm not wed to either of these, just what I found on the internet. Trying to give the ZD 1211 as much grip on hills as I can.
Thanks for your help!
   / ZD 1211 Tires Change Question #12
Tires are more plentiful & cheaper for the smaller rim size but you’ll have more sidewall give IF you mow rough ground or have stump holes Causing scalping IF you mow shorter.
   / ZD 1211 Tires Change Question #13
I should have known you would have Bota ZTs. I just bought a 1211.
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2015 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
Brent 644 S/N B29830123 (A52128)
Brent 644 S/N...
2012 Jaguar XJ Sedan (A50324)
2012 Jaguar XJ...
