Z724 Hot Start
/ Z724 Hot Start #1
timswi
Super Member
Beaver County Pa
Kubota BX23 TLB, Kubota RTV1100, Kubota Z724 & Polaris RZR 900 Trail
Have a Z724...Cold starts are very quick with no issues. Seems when I restart after mowing (5-15 min after) it sometimes has difficulty getting to WOT RPM. Never stalls but seems to struggle for 10 seconds or so. All new filters etc...Any ideas?
Also, since this was new it will puff what appears to be blue smoke when starting hot or cold. Doesn't use any oil at all. Koehler engine. Was told this is normal--Find that hard to believe.
/ Z724 Hot Start #2
It is a good idea to let it idle for a minute or two with no load before shutting down, that may help. As far as blue smoke, my 26HP Koehler power riding mower would smoke turning a corner. The way to eliminate that issue is to run the oil level no more than 3/4's of the way up between the add and full marks on the dipstick.
/ Z724 Hot Start #3
it's normal for a new engine to smoke a bit until the rings wear in!.. then it will stop smoking..
/ Z724 Hot Start
Well, it does have 100ish hours on it...Would have thunk they would be seated by now...Dunno, not hurting anything I guess.
/ Z724 Hot Start #5
I don't have a ZTR. I do have a mower with a twin cylinder Kohler. If I park it slightly nose down it will smoke when started, though it doesn't seem to use oil between changes. I've taken to parking slightly uphill (backing into its parking place) and the smoking has stopped.
New Landhonor 72" Rock Bucket (A62679)
New Landhonor 72"...
Skid Steer Rotary Cutter (A65640)
Skid Steer Rotary...
(16) Kinze 3000 Seed Boxes (A65640)
(16) Kinze 3000...
2017 Hyundai Trailer (A62613)
2017 Hyundai...
Cattle Feeder (A65640)
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
