YT359 whining issues
/ YT359 whining issues #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
I have 132 Hours on my machine, and a few months back I was using the backhoe and I started to get a high patch whining at 2000RPM. As soon as you move the loader stick it stops but comes back when you let it go. At this point I have disconnected all the lines reconnected everything made sure there was no leaks check the fluid level and the dealer sent me a new loader Val that I replaced and its still doing it. Anybody have any other ideas?
/ YT359 whining issues #2
Certainly sounds like a loader valve issue. I wonder if there are any adjustments on the valve, to center the reliefs when the lever is neutral?
Im not sure. They sent me a brand new valve that I put on but it's still doing it
/ YT359 whining issues #4
Could it be the relief valve? Like because some downstream hydraulic control like rear remotes is dead headed?
/ YT359 whining issues #5
Sounds reasonable. Do you have a video of when it's making the sound?
/ YT359 whining issues #6
Check to make sure one of your hydraulic control levers is not stuck in a weird position or the adjustment has changed on the cable to the rear hydraulic control unit.
