YT359 whining issues
   / YT359 whining issues #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
I have 132 Hours on my machine, and a few months back I was using the backhoe and I started to get a high patch whining at 2000RPM. As soon as you move the loader stick it stops but comes back when you let it go. At this point I have disconnected all the lines reconnected everything made sure there was no leaks check the fluid level and the dealer sent me a new loader Val that I replaced and its still doing it. Anybody have any other ideas?
   / YT359 whining issues #2
Certainly sounds like a loader valve issue. I wonder if there are any adjustments on the valve, to center the reliefs when the lever is neutral?
Im not sure. They sent me a brand new valve that I put on but it's still doing it
   / YT359 whining issues #5
Could it be the relief valve? Like because some downstream hydraulic control like rear remotes is dead headed?
Sounds reasonable. Do you have a video of when it's making the sound?
   / YT359 whining issues #6
Check to make sure one of your hydraulic control levers is not stuck in a weird position or the adjustment has changed on the cable to the rear hydraulic control unit.
42in Hydraulic Forks Forklift Attachment (A49346)
42in Hydraulic...
2020 Dodge Grand Caravan SE Van (A48082)
2020 Dodge Grand...
UNUSED CFG SKID STEER AUGER SET (A50460)
UNUSED CFG SKID...
2022 Club Car...
Linde H35D 4,350lb Forklift (A49346)
Linde H35D 4,350lb...
2007 MACK GRANITE ROLL OFF TRUCK (A50505)
2007 MACK GRANITE...
