YT3 Low range - LOW RPM
/ YT3 Low range - LOW RPM #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
What am i missing?
When I shift the transmission into 'A' range the engine speed drops almost to idle and won't budge regardless of position of the throttle lever or foot pedal. I don't see anything in the manual that would guide me. I admit that I haven't spent a lot of time on this
/ YT3 Low range - LOW RPM #2
What is your RPM set to on the AB mode switch?
/ YT3 Low range - LOW RPM #4
The RPM's on my tractor actually increase when I switch over to A range because my AB setting is set at 2600 RPM. I am using A range to run my PTO implements.
/ YT3 Low range - LOW RPM #5
Knotch is probably onto the issue. You probably have RPM set super low in "a" mode. Just increase the RPM setting and you will be good.
I still haven't tried it! I forget when I am using and remember when I am miles away!
/ YT3 Low range - LOW RPM #7
correct me if I am wrong please, but aren't A and B just electronic throttle/speed presets?
It should have nothing to do with the "gear" the tractor is in
/ YT3 Low range - LOW RPM #8
Groo,
A and B set the maximum engine RPM and Speed regardless of gear. So if A mode is one and the RPM is set to say 1000, the tractor will never go above 1k RPM unless the mode is changed or the setting in A is changes. Or say you set the speed at 2 MPH, it will only go 2 MPH no matter what range you are in or RPM the engine is at.
Chris
It was the cruise setting. When I turned up the dial the engine runs faster, mow. It was only affecting A range.
