Mowing YRM 60A YANMAR MOWER
/ YRM 60A YANMAR MOWER #1
NCGMAN
NORTH CAROLINA
YANMAR
Anybody got any experience with these mowers?? When I purchased the YM226, this mower came with it. Well I hooked it up and it worked ok, so I decided to kinda restore it. Stripping it down,, tough job,, everything is frozen up. Well I only had to retap one hole, plus using a whole can of lubricant. One of the bearings sounds a little to noisey to me, so am going to remove it and see if I can get one. On the Yanmar plate, it says manufactured in the USA.. Let's see if Napa can match the bearing!!!!!
The blades are new... Now that will probably be an experience,, getting blades for it....
/ YRM 60A YANMAR MOWER #2
I have the OEM bearings & Blades available.
Danny
Might not be able to get the blade off. Have worked on it for about four hours,,, heating,,, hot, hot, hot,,, WD 40 -- one can!!! air impact !!!! Has not budged. Do you have one of these???
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
Ford 555C 4x4 Loader Backhoe (A59228)
Ford 555C 4x4...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2016 Kenworth T680 20 Yard Tri Axle Dump Truck (A59230)
2016 Kenworth T680...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
