YQM-48 & Over-Running Clutch Question
   / YQM-48 & Over-Running Clutch Question #1
richriddle
Taylorsport, Kentucky
Kubota L4330 with LA853 Loader, Yanmar YM276D with YFL1000 Loader, Yanmar YM276D, Yanmar YM147D, Case 1845C
Is it possible to utilize an over-running clutch with the YQM-48 belly mower on the YM147D? Actually, I am wondering if it's needed at all as well. Thank you.
   / YQM-48 & Over-Running Clutch Question #2
That's an American model Yanmar, no? You might already have an over-running clutch.
Unhook the mower and try turning its pto (on the tractor) backward. Or just turn the blade(s) backward if you can. If you hear clicking like a bicycle coasting along, that's the over-running clutch working as it should. This test works on a rear pto and should work on a belly pto as well.
California,
It is an American model. The PTO has no implements on it, so I will attempt to turn it backwards as you recommend. The mower attaches to the rear PTO when installed. Thank you.
Winston1,
Thanks for the link. I didn't realize they provided that information.
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
SKID STEER HYDRAULIC TREE PULLER (A52472)
SKID STEER...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
