Your towing rigs and trailers
   / Your towing rigs and trailers #3,581
I think with today’s trucks the comparison is the same. It the gross vehicle weight minus the curb weight = the payload. The payload includes all fluids and full fuel but no people. The tow rating is the same but includes a 150 pound driver. Most half tons are limited by the payload, which is the hitch weight, for towing.
   / Your towing rigs and trailers #3,582
At some point I'll stop by some truck scales & get an actual curb weight...
   / Your towing rigs and trailers #3,583
^ this is why I like having a 9200 lb GVWR with sub 5800 lb curb weight on my 2500HD, even though its mostly overkill for my homeowner needs. Never have to think about splitting up pallets of brick, pavers, block, etc.
I don't know how you guys get by with these 1000-1500 lb payload ratings.... put your family in the cab and you're nearly tapped out. Well, actually I do know, many of you probably just regularly exceed the rating. :laughing:
Mine is 9800 with 6800 curb weight. But that’s really more of a suggestion.. IMG_7771.JPGIMG_8923.JPG
   / Your towing rigs and trailers #3,584
These days the actual payload of your truck will be on the door jamb sticker, usually a yellow and white sticker. The guides are often a joke and list higher than actual numbers.
My ram has a GVWR of 19,500. It was easy to calculate payload by simply weighing my truck with its secondary body, fuel cell and typical load of tools, which was about 10,200lbs. So payload is about 9300lbs. GCWR is 43000lbs. I weighed truck (same parameters as before, but with my trailer in tow). That combined weight was 18,5000lbs. That leaves me with a truck & trailer payload of ~24500lbs.
   / Your towing rigs and trailers #3,585
I had the same experience with the various brochures and towing guides from the manufacturers being unreliable for cargo and tow ratings. If you're lucky they will be within 400#. The doorjamb sticker (or sometimes in the glove box) is the most accurate data and will usually be specific to the VIN or configuration and trim level.
The loaded up trucks suffer in cargo capacity, no doubt about it. You're trading off cargo capacity for options, crew cab, etc (and you carry it around all the time). And at least with GMC, going with the heavier engine options also deducts from cargo capacity. In a GMC, if you care about cargo or towing capacity, best option is a lower trim level with the smaller V8 and avoid crew cab. That can gain 200-500# in extra capacity for cargo and towing.
I hear a lot of people proclaim that the bigger engines are better for towing. Well, they might feel stronger when towing, but they also knock down the towing capacity. I think there is a couple hundred pound loss in tow rating with the larger V8 in GMC.
The 5.3 and 6.2 are the same block. There is very little weight difference. The 10 speed trans may add weight.
   / Your towing rigs and trailers #3,586
The specs do not specify whether it's due to the engine or something else, nor did I mean to imply that. But I have compared the door jamb stickers on mechanically equivalent trucks with the same transmission and rear end, and the 5.3L models always have higher tow and cargo ratings. If you can find apples to apples trucks, the tow/cargo ratings are highest on 5.3L, 3.0 diesel is in the middle, and 6.3L has the lowest. There is usually 200-300# spread. It is known that the diesel is limited by cooling (for emissions purposes it's designed to run hot) otherwise it would probably do better.
   / Your towing rigs and trailers #3,587
It's likely because the 6.2 is tuned for performance. So it may run hotter towing. The ratings are based on people too stupid to monitor things. Also the higher power may be too much for the rest of the drive train when towing. All the newer diesels are problematic due to emissions garbage. Same problem in big trucks. They keep the towing companies strong and growing.
   / Your towing rigs and trailers #3,588
Recently bought a used 1989 JD 770 with 475hrs on the clock. My 2013 F150 pulls it nicely with a 16ft dovetail trailer I have from Rampant Trailers in NC. Use the trailer often pulling large supplies and my Classic tagged 1984 Jeep CJ-7 I've owned since new.
   / Your towing rigs and trailers #3,589
Nice looking setup. It looks like you spent some time on the trailer getting it setup the way you want, very nice.
   / Your towing rigs and trailers #3,590
Metal Goat Family (A57454)
Metal Goat Family...
2016 Sun Coastal 16' Cargo Trailer (A57148)
2016 Sun Coastal...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
2012 Kenworth T800 Heavy Haul Truck, VIN # 1XKDD40X6CR301872 (A57453)
2012 Kenworth T800...
2015 Ford Transit 150 Cargo Van (A56858)
2015 Ford Transit...
