Your towing rigs and trailers
   / Your towing rigs and trailers #501
Are you obsessed with rear end squat?
The more the rear end squats the less weight there is on the front wheels which control the truck, so he should be obsessed with rear end squat. I am and so should everyone else that tows anything. My RAM sat perfectly level with my tractor and trailer (7000lbs +/-) and if it squated more then I would have put a load distribution hitch on it.
   / Your towing rigs and trailers #502
How does the squat from weight of a gooseneck trailer take weight of the front end?
   / Your towing rigs and trailers #503
Thanks, I couldn't have said it better. Thanks for shifting the thread from personal attacks back to the topic. If you can believe it, the picture I showed of my previous F-350 ford with excessive squat was actually equipped with rear helper springs to get rid of the squat from the factory springs. Even the aftermarket helpers couldn't keep my F-350 from squatting with only a 9K trailer.
   / Your towing rigs and trailers #504
The thread topic is "your towing rigs and trailers". As you should be able to see, that could mean gooseneck or bumper pull. When you have bumper pull squat, weight is taken off the front, resulting in loss of steering control and visibility out the front.
   / Your towing rigs and trailers #505
Not neccessarilly
Just because one brand squats 1" farther than a another brand, with all else the same, doesn't mean it takes more weight of the front end.
And your original comment was about a GN trailer.:rolleyes:
   / Your towing rigs and trailers #506
I did, right here:
If you can believe it, the picture I showed of my previous F-350 ord with excessive squat was actually equipped with rear helper springs to get rid of the squat from the factory springs. Even the aftermarket helpers couldn't keep my F-350 from squatting with only a 9K trailer.
Dmace answered your "obssessed with......." question perfectly. :)
   / Your towing rigs and trailers #507
Not neccessarilly
My comments were about all trailers. Look at the front end of my truck while towing a light trailer. You can see the front end is up and weight has been taken off the front axle. When I towed heavier equipment, it was worse. That is why I am "obsessed" as you call it, about rear axle squat.
http://good-times.webshots.com/photo/2957149550034043331MyXNxN
   / Your towing rigs and trailers #508
Your kidding right.
Your truck is either lifted or has the extra heavy front springs (for a plow or something?).
   / Your towing rigs and trailers #509
Any time you put a trailer on your bumper you take weight off your front end,a goose neck fifth wheel moves up the weight dist. foward in which lessens the weight taken off your front end,but over weight even with a goose neck can take away from your front end weight.youd have to mount the hitch point directally in the middle of your vechile.Same way if you loaded your trl at the rear youd take weight off the back of your truck and thats not good if you are over weight. hope this helps
   / Your towing rigs and trailers #510
Proper pin placement for a GN is forward of the rear axle, so how can you take weight off the front axle?
2019 Chrysler 300 Sedan (A55853)
2019 Chrysler 300...
Margaritaville Wall Art (A55853)
Margaritaville...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
2003 Sailfish 188 18ft. Boat with S/A 20ft Boat Trailer (A55853)
2003 Sailfish 188...
