Your towing rigs and trailers
   / Your towing rigs and trailers #261
Here's my setup:
- 2008 LWL LT 16', "light tandem" 7000# GVW, brakes on all 4 wheels.
- "Old Reliable" - 1979 Ford F100, 300 cu.in. 6 cyl., T-18 4-speed, 6-leaf rear springs - built to work!
- Kubota B7800 chained down with 3/8" G70 at each corner, plus 3/8" G70 through the FEL tube.
   / Your towing rigs and trailers #262
'05 Dodge 2500 Cummins, '07 Jinma 284, '00 Big Tex 16' 7K w/ chains on all 4 corners plus one each over attachments, just like common sense and the terms of my CDL require... ;)
   / Your towing rigs and trailers #263
Please tell me that I'm just not seeing the 4 chains on each corner holding the tractor to the trailer. I know I can't see everything from the limited picture. It's just that from the picture I see, it appears to be a candidate for the Darwin Award with one flimsy ratcheting strap across the floor of the tractor, which wouldn't be adequate for even holding a 4 wheeler on the trailer.
dargo
I used the winch on the front and a cumalong on the back strapped to the loader and put the rachet strap over the middle.I hope this makes you feel better...:)
   / Your towing rigs and trailers #264
Mine is a 1996 F150 4X4 short wheel base that I use to pull the 16 foot bumper pull and 2 horse trailer. I play in the dirt too. My wife's is a 2004 F350 PSD 4 door Lariat and 3 horse Exiss slant. We like em both!! Tractor is a Montana 2740.
It's useless without pictures!!
Matt
   / Your towing rigs and trailers #266
My 98 Dakota 4x4, 5.2 litre with a 7000 lb. trailer with elec brakes both axles.
I use 4 10,000 lb ratchet straps 1 on each corner plus one over the loader by bucket & 1
on the backhoe bucket. At all wear areas I have the straps fed thru pieces of fire hose
to save the straps. This setup works well with my Kioti Ck20.
   / Your towing rigs and trailers #267
It's amazing what those Dakotas will do, they are a perfect match for someone who needs a truck that can tow but not a big 1/2ton. My 98 V6 3.9l hauled three sleds with 3 men and all their gear 3hrs north up through the steep White Mountains highway every weekend in the winter. It was a little tight inside but that V6 had plenty of power and the truck had great brakes.
click for larger image
   / Your towing rigs and trailers #268
Our rig as a 2003 Chevy 2500 Vortec ext. cab, long bed. Tow 6 ton deckover and a single axle 5x12 landscape trailer haulin whatever you see in my signature, profile, and more. Sorry, no pictures, try to get some up soon!
   / Your towing rigs and trailers #269
Here is mine. Yea, its got a HEMI, no CTD here but handles the trailer fine.
   / Your towing rigs and trailers #270
One of my Trailers. 18' Legend all aluminum Trailer and its contents. The 7 Ton dump trailer before I fixed it up from previous owner.
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2016 Ford F-250 4x4 Reading Service Truck (A55852)
2016 Ford F-250...
2014 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Mack CXU613...
