Your towing rigs and trailers
   / Your towing rigs and trailers #261
Here's my setup:
- 2008 LWL LT 16', "light tandem" 7000# GVW, brakes on all 4 wheels.
- "Old Reliable" - 1979 Ford F100, 300 cu.in. 6 cyl., T-18 4-speed, 6-leaf rear springs - built to work!
- Kubota B7800 chained down with 3/8" G70 at each corner, plus 3/8" G70 through the FEL tube.
   / Your towing rigs and trailers #262
'05 Dodge 2500 Cummins, '07 Jinma 284, '00 Big Tex 16' 7K w/ chains on all 4 corners plus one each over attachments, just like common sense and the terms of my CDL require... ;)
   / Your towing rigs and trailers #263
Please tell me that I'm just not seeing the 4 chains on each corner holding the tractor to the trailer. I know I can't see everything from the limited picture. It's just that from the picture I see, it appears to be a candidate for the Darwin Award with one flimsy ratcheting strap across the floor of the tractor, which wouldn't be adequate for even holding a 4 wheeler on the trailer.
dargo
I used the winch on the front and a cumalong on the back strapped to the loader and put the rachet strap over the middle.I hope this makes you feel better...:)
   / Your towing rigs and trailers #264
Mine is a 1996 F150 4X4 short wheel base that I use to pull the 16 foot bumper pull and 2 horse trailer. I play in the dirt too. My wife's is a 2004 F350 PSD 4 door Lariat and 3 horse Exiss slant. We like em both!! Tractor is a Montana 2740.
It's useless without pictures!!
Matt
   / Your towing rigs and trailers #266
My 98 Dakota 4x4, 5.2 litre with a 7000 lb. trailer with elec brakes both axles.
I use 4 10,000 lb ratchet straps 1 on each corner plus one over the loader by bucket & 1
on the backhoe bucket. At all wear areas I have the straps fed thru pieces of fire hose
to save the straps. This setup works well with my Kioti Ck20.
   / Your towing rigs and trailers #267
It's amazing what those Dakotas will do, they are a perfect match for someone who needs a truck that can tow but not a big 1/2ton. My 98 V6 3.9l hauled three sleds with 3 men and all their gear 3hrs north up through the steep White Mountains highway every weekend in the winter. It was a little tight inside but that V6 had plenty of power and the truck had great brakes.
click for larger image
   / Your towing rigs and trailers #268
Our rig as a 2003 Chevy 2500 Vortec ext. cab, long bed. Tow 6 ton deckover and a single axle 5x12 landscape trailer haulin whatever you see in my signature, profile, and more. Sorry, no pictures, try to get some up soon!
   / Your towing rigs and trailers #269
Here is mine. Yea, its got a HEMI, no CTD here but handles the trailer fine.
   / Your towing rigs and trailers #270
One of my Trailers. 18' Legend all aluminum Trailer and its contents. The 7 Ton dump trailer before I fixed it up from previous owner.
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
2019 BOMAG BW120AD-5 SMOOTH DBL DRUM ROLLER (A52707)
2019 BOMAG...
1640 (A57192)
1640 (A57192)
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
1339 (A57192)
1339 (A57192)
