Your last generator Maintenance Run
   / Your last generator Maintenance Run #6,621
I know I've ran my hot tub heater and recirc pump on my big generator, not sure if I've ran the jet pump or not. I'm sure it would work with the heater off.
Not on a 28v generator
   / Your last generator Maintenance Run #6,622
Of course not, I don't think the person asking about running a hot tub was referring to a 28vdc generator.
   / Your last generator Maintenance Run #6,623
Agreed, I'd like a small load bank, but have not seen those in consumer/homeowner size.
I’ve got a 5kw load bank that’s Honda branded, but was made by Sotcher Measurement.
Definitely in consumer size.
   / Your last generator Maintenance Run #6,624
   / Your last generator Maintenance Run #6,625
   / Your last generator Maintenance Run #6,626
   / Your last generator Maintenance Run #6,627
90Cummins, nice engine, not sure what the tech is behind "soft gears" but
I bet it runs smoothly. They promote fuel efficiency, what is the gpm
under full load? A gallon of diesel may go a long time.
two gens is belt and suspenders. Three gens is having fun
   / Your last generator Maintenance Run #6,628
   / Your last generator Maintenance Run #6,629
Is this model still available?
I have never seen another like it.
Apparently very limited production & use.
Not show in literature are the two intake grid style (Cummins) style intake air heaters that permit subzero starting which I verified and posted on utube.
The following link should bring you to some videos of testing I’ve done in past. Not all pertain to generators.
I have fuel consumption details of past testing and will post if/when I find them.
   / Your last generator Maintenance Run #6,630
Fired up the generator in the 5th wheel last night. Had to spin it 4 times I think. It finally caught & ran fine. Hadn't started it since the fall & we have a foot of snow falling today. Wanted to exercise it & make sure it was working if we loose power.
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
BUCKET MOUNTED ASPHALT CUTTER (A52708)
BUCKET MOUNTED...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2008 International 7500 Altec A77-TE93 92ft. Material Handling T/A Bucket Truck (A55973)
2008 International...
JOHN DEERE 544G WHEEL LOADER (A58216)
JOHN DEERE 544G...
2015 Chevrolet 2500 Silverado 4X4 Crew Cab Pickup Truck (A55973)
2015 Chevrolet...
